Page 1 of 6 1234 ... LastLast
Results 1 to 10 of 58
  1. #1
    Gold Member keving's Avatar
    Join Date
    Jun 2006
    Posts
    368
    Virginia/WV
    Kubota 7040HDC
    Default 40x60 Metal Building Cost?
    I'm planning on buying a 40x60 metal building with a 16' eve with at 4/12 pitch. I'm trying to get a ballpark of what others have paid for:
    Site prep - my site is pretty level with no trees and easy access
    Concrete - 6" thick with rebar
    40x60x16 with at 4/12 or 6/12 pitch
    insulation package
    one 12x14' rollup door
    one 10x10' rollup door
    2 regular entrance doors
    Any info in part would be appreciated. If you assembled yours yourself, how hard was it? I am looking at an Olympia Steel Building. Anybody have feedback on their buildings?
    keving
    M9540HDC
  2. #2
    Veteran Member mikim's Avatar
    Join Date
    Feb 2001
    Posts
    2,066
    Paige Texas
    NH TC45
    Default Re: 40x60 Metal Building Cost?
    here's mine -- 30X50 x12 on 4" slab with #3 rebar on 12" ( #5 bar in the footers and berms) - 20x50 leanto attached w/no slab -- 2 10x10 rollup doors, 1 personnel door, 2 windows, insulated .... I didn't turn a hand -- $32,950 ...... I really wanted a 40x60 -- but it busted the budget. the leanto has sides added now - they weren't done in this pic................
    edit .... added other side view ....
    Attached Images Attached Images
    Mike
  3. #3
    Elite Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    4,662
    62014 IL (outside STL MO)
    New holland TC(33)
    my 32x60x12 wood truss pole barn
    no concreet floor, no insulation 2 huge sliding doors (one front one side) and a man door.
    free (with 4.5 acers and rundown house for $53K)
    i was told to ballpark 15K if i wanted to build it... obiously concreet and insulation will add (significantly.... half again as much?) to that...
    http://www.snjschmidt.com/pics/property/poll_barn.jpg
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  4. #4
    Join Date
    Jan 2002
    Posts
    1,927
    Home-1+ acres New Hope, TX / 24 acres-Fannin County
    JD 950
    Nice looking building Mike. Who did that one for you?
    Bill
    "Whatever you are, be a good one." Abe Lincoln
  5. #5
    Elite Member
    Join Date
    Jul 2006
    Posts
    3,010
    midwest
    JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
    I have a Menards 45'x72'x12' pole barn put up 5 years ago. 12" overhang, wainscoting, 22' end sliding door, 10x12 roll up door on side, 2 walk in doors, 4 windows, with laminated poles and 8' rafters on center and 8 skylights. Paid about $16,000 for the building. $12,000 to put up. 1 year later put in 5-6" cement with rebar for $9,000 and my labor. Later built a heated shop area 24x24 inside and had building wired then. I am sure prices have gone up.
    Also looked same size Cleary and Astro building erected for about $32,000-$35,000. Morton was approaching near $40,000 erected.
    My brother had a 60x100x16 Astro pole barn with no windows, 2 walk in doors and 2 large end sliding doors, 10' center rafters and put up for about $60,000 2 years ago.
  6. #6
    Gold Member kentrodngun's Avatar
    Join Date
    Jul 2005
    Posts
    422
    New York (Southern Tier)
    Kioti LK3054 & DitchWitch R40 Trencher/Backhoe
    I put up a 40x50 pre-fab made by Heritage.
    Heritage Building Systems | Steel Buildings, Prefabricated Metal Building
    Walls were 12' at the side and 17' at the peak, roof pitch was increased to 3/12, wind resistance was bumped up to 115 mph, three 10x10 overhead doors, four windows, one entry door and 4" insulation in the walls & ceiling and gutters & leaders. Total cost including delivery was ~16,000.
    Excavation required significant leveling of the site, digging for the foundation, backfilling & tamping. Cost was ~6,600.
    Foundation included a footing, four foot high frost wall, all the anchor bolts and a 6" floor (everything rebarred, meshed & polished) 3500 psi. Cost of that was ~16,000
    Erection of the building was done by me, my son and future son-in-law (both a mere 23 yoa) over an eight week period which excluded weekends and rainy days. I figured our total hours were ~750. Cost of slave labor (including beer) ~2,500.
    I priced out having someone else erect it and it ran anywhere from 3.50 to 5.00 per square foot - my last quote was ~8,900 for my 2,000 sq ft building.
    Putting the shell together was interesting and took about 150 hours. You'll run into some fitting issues but nothing that can't be handled using the old noodle. If you decide to do it yourself, I'd be happy to share my do and do not list with you. I learned a lot through my mistakes - I can save you some grief.
    The guys at Heritage were very helpful, they make a quality product, and IF you carefully read their plans and booklet, you CAN do it yourself.
  7. #7
    Elite Member
    Join Date
    Apr 2000
    Posts
    3,408
    Grayson County, TX
    Kubota B2710
    My 40 x 60 building was built in 2000 for about $22,000, plus about $10,000 for the slab. It has 14' walls and 4-pitch, a personnel door, an 18 x 12 door and a 10 x 12 door. Also has insulation and gutters. Its a weldup rather than kit.
    Alan L., TX
    South of Bugtussle
    North of Mustang
    On the banks of Buck Creek
    We don't rent pigs.
  8. #8
    Join Date
    Feb 2001
    Posts
    2,066
    Paige Texas
    NH TC45
    very local fella - like 4 miles away - he was trying to startup as a metal building contractor and do lots of commercial stuff etc .... but the last I heard he wasn't finding enough business to feed the family so went to work elsewhere. He still does it - cause I see he still has a sign out front - but I don't know how much he's still doing. I went with him cause after I met with him and his wife -- we liked 'em, they are neighbors, he was priced reasonable for a turn-key, and with a name like "Mike's Metal" how could I go wrong?
    Mike
  9. #9
    Elite Member
    Join Date
    Nov 2005
    Posts
    2,568
    Virginia
    1949 farmall, 1961 Fordson Dexta, 1986 Duetz Allis, 2001 Kubota.
    I don't know how far their crews travel, but Stoneburner out of Harrionburg Va. did a fantastic job building my 24' X 36' X 10' for about $16,000 including concret work, walkin door and two overhead doors.
    mark
    red tractor
    blue tractor
    green tractor
    orange tractor
    too many impliments to list
  10. #10
    Join Date
    Jun 2006
    Posts
    368
    Virginia/WV
    Kubota 7040HDC
    Quote Originally Posted by mjarrels
    mark
    Mark,
    Can you PM me with their contact info?
    Thanks,
    Kevin
    keving
    M9540HDC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
