I tied the tow strap to the FEL and pulled the pole away from the tree. In the position shown, I decided to lift the bottom of the pole by hand to see how heavy it was. To my surprise it was very light. I figured out later that the pole weighted only about 80 lbs without the electrical gear attached.
We laid the pole on the ground and removed the meter box. I intended to cut off 2 feet from the conduit above the meter box and re-assemble the meter box, mobile home panel, RV jack, end 120V receptacle two feet higher on the pole (to account for the hole that was 2 feet deeper). However, we noticed that the conduit was glued to the threaded plastic collar at the top of the meter box so we couldn't re-use the collar. Consequently, we removed the conduit from the pole and put all the electrical pieces in the truck to take home with us. We would purchase the required parts during the week and return the next weekend to re-assemble everything on the pole.
