3PH log skidding implement
   / 3PH log skidding implement #1
patrick_g
Elite Member
South Central OK
Kubota Grand L-4610HSTC
I have been doing a little more than my average logging lately and have tired of improvising. Here is my trial baloon... What do you think?
1. Cut a piece of steel, probably 4 inch heavy wall steel pipe or square tubing (1/4 or more wall thickness) to fit between the 3PH lower arms of a class 1.
2. Drill centered holes in 4 pieces of 1/4 plate, 2 to fit inside the pipe and 2 larger than the pipe. Two are cut round to fit inside the pipe and the larger ones are about 6-9 inched in dia.
3. The holes in the centers to fit class 1 pins.
4. Distribute the round center drilled plugs on the pin and weld together with the larger on on the end.
5. Drill some holes in the pipe at the location where the plug(s) will be when inserted in the pipe (except the outermost.)
6. Weld the plugs through the holes and all the way round on the outer one.
That's it!
Insert this "implement" in the lower arms and secure like any other implement. Attach a chain to the drawbar and run it over the top of the "implement."
In use you back up to a log and lower the 3PH. You then attach the chain. You can now raise the hitch to pick up the end of the log and drive away forward pulling the log. The larger round pieces at the end help keep the chain from getting off of the pipe at the ends. You might not want to raise the 3Ph any more than needed to prevent the end of the log from digging in or bringing you to a sudden halt if the towed log hits a stump. Raising the log too high places the rearward force above your rear axle and takes weight off your front tires reducing your steering ability as well as promoting a potential rearward roll over.
I have no clue what the smart guys do but this seemed like a big improvement over my usual improvised approaches and it shouldn't take a real welding engineer to build.
Pat
   / 3PH log skidding implement #2
It seems if you use a drawbar and a clevis and hook either tongs or a chain to it you have the same thing. If thats what you're talking about.
   / 3PH log skidding implement #3
I'd just build a logging arch and be done with the thinkin' and get on with the doin' ... but that's just me :D
   / 3PH log skidding implement #4
ok for us unknowing people. What is a logging arch ?
   / 3PH log skidding implement #5
Practically an unlimited supply of links via a simple Yahoo search and, several on TBN (if the search function actually works) but, this link brings an age-old implement up to date :D
   / 3PH log skidding implement #6
Thank you for answering my question. That is seriously cool. I would never need one because I dont log but it is nice to increase my pool of knowledge.
   / 3PH log skidding implement #7
Couldn't resist my 2 cents worth. I've been a parttime logger since August 05 Hurricane Katrina (lost $72k in pine timber). 3pth boompole - $60, logging tongs - $60, 6 ft chain - $20, pull anything you can get the tongs around = priceless.
Seriously, you can drag/lift practically anything if you hook up closer to the hitch rather that the far end of a boompole. I even use the boompole to lift 1 log, chain it and then tong the second log, lifting both to drag. The boompole will allow you to reach into and over stuff to grab a log. I haven't met a log I couldn't drag yet. Remember the shorter they are, the easier to drag!
   / 3PH log skidding implement #8
I too have been skidding logs with a tractor as a result of Katrina and found the "3-point quick hitch" comes in handy as a device for attaching chains and log tongs. Because of its U-shape, it allows you to lower the hitch over the end of a log where you attach your tongs and chain for skidding. Raising the hitch with the attached log then clears the height of most obstructions (stumps) but not higher than the rear axle. Always have your ROPS in place when skidding logs.
MSWoodlot
   / 3PH log skidding implement #9
What about something like this Pat?:D
   / 3PH log skidding implement #10
I also built a logging arch over 20 years ago, then it cost me about $60.00.
It can handle a single 30" diameter log 16' long or 2 or 3 smaller diameter ones.
The good thing is the whole log is off the ground so there is less ground damage and less dirt on the log and less chance of the tractor rearing up from the loog stalling out on a root, stump, or rock.
I mounted a hand operated boat winch on the rear of the arch which can pull a log into place under the arch and lift the back end off the ground. If i get the balance right I can run a chain under the front of the log and lift it off the ground by hand.
Using the 3PH lifted high to pull something as heavy as a log worries me that the front of the tractor could get light without weight in the FEL.
Randy
2016 Ford F-150 Pickup Truck (A55973)
2016 Ford F-150...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Deere 325G (A57148)
Deere 325G (A57148)
