bbirder said:I agree with Ron. Sorry, didn't look at the pics or read the post thoroughly. Flashing probably wont help.
Oops me neither And I agree flashing isn't gonna help.
RonMar said:Flashing the field probably won't do much good with that burnt component on the regulator board. There is only those 4 wires between generator housing and box? I would have expected 5 or 6(two hots, neutral and maybe a ground, as well as the 2 leadsto feed the field winding). That burnt board is most likley the voltage regulator. It takes a little of the generated power and sends it back to the rotating field via the aformentioned brushes or a separate induction coil. The amount sent back, controls the amount of voltage generated. IF that part is smoked, you might have a hard time finding just what that part is to replace, and what caused it to fail also. And as voltage regulators go, it would probably cost as much for that regulator board, if you can find it, as for a newer replacement generator...
Good Luck
RonMar said:Without excitation, that output voltage sounds about right. I am guessing that you got voltage on 2 of the wires?
Soundguy said:Quite honestly, i wouldn't invest a dime in doing anything else unless I got the regulator board part first...
soundguy
