HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Other Forums > Related Topics
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-05-2009, 10:18 AM   #11 (permalink)
Super Star Member
jinman's Avatar
Default Re: 94 Ford F250 battery cable
I agree with J_J, except to say that sometimes cable connections may have lots of corrosion as far as 1-1/2" up inside the insulation. I think you are going to have to find a way to clean off the corrosion and neutralize the acid before crimping on a new connector. The perfect crimp connection will be so tight that it will be liquid and even vapor proof. It's not likely you will be able to reproduce such a good connection by doing it on the truck, but it may be good enough to last a very long time if you get it clean enough. Preparation of the wire before crimping will easily be 80% to 90% of the job. Starting a diesel pulls so much current from your batteries that you need every little strand of wire to do its job or the connection will overheat and bad things will happen.
__________________
Jim
jinman is offline   Reply With Quote
Old 10-05-2009, 10:37 AM   #12 (permalink)
Gold Member
You could soak the end in a cup of Coke Cola for 5 or 10 minutes then wipe with oil. Has always worked for me on battery post/connections. I pour a Coke on it, dry it off and oil.
I never get corrosion.
Western is offline   Reply With Quote
Old 10-05-2009, 06:05 PM   #13 (permalink)
If you can't get insulation all around the metal, a nice gob of dielectric grease will keep it from corroding....of course you then have a nice gob of grease to collect junk.
Chuck
Chuck52 is offline   Reply With Quote
Old 10-05-2009, 10:40 PM   #14 (permalink)
Dmace's Avatar
You shouldn't have a problem getting that connector on without removing the cable. Removing the cable is not easy, I replaced that cable on my 94 F-350 diesel when I replaced the starter.
If you cannot get the crimp tool from your local parts store as a rental then try using a C-clamp. I have been able to start crimping a connector with a large C-clamp and finish it off with a hammer.
__________________
Derek
Kioti CK20HST
KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
Sims-Cab Depot heated cab
Pics
Dmace is offline   Reply With Quote
Old 10-07-2009, 06:39 AM   #15 (permalink)
IH3444's Avatar
Solder it in....That's what I do to all of my battery/wire connectors. Crimping encourages corrosion pockets. Besure to clean off all flux paste. Fill that void up with solder.
IH3444 is offline   Reply With Quote
Old 10-07-2009, 08:16 AM   #16 (permalink)
czechsonofagun's Avatar
Send a message via ICQ to czechsonofagun
Quote:
Exactly my point - great minds think alike
__________________
Regards,
Prokop
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
czechsonofagun is offline   Reply With Quote
Old 10-07-2009, 10:15 AM   #17 (permalink)
Super Star Member
jinman's Avatar
If you solder, do not use plumbing acid flux. Electrical soldering should use rosin flux only. You can clean off the rosin flux with isopropyl alcohol (rubbing alcohol).
__________________
Jim
Old 10-07-2009, 12:24 PM   #18 (permalink)
IH3444's Avatar
I usually use the electrical solder that has the flux already with it. And as Czech says use shrink tubing. That's what I do also. Then cover with either another layer of shrink, and or back over the joint with electrical tape. Ready for Indy, or the moon shot. hehehe
Old 10-07-2009, 01:10 PM   #19 (permalink)
Instead of standard electrical tape I might use the new epoxy tape that bonds to itself and makes a nice seal. I've used it only for plumbing so far, but it says on the packaging that it is also good for electrical insulation, and unlike standard electrical tape, when it is applied properly it shouldn't come unwound.
Chuck
Old 10-08-2009, 04:13 PM   #20 (permalink)
Are we talking solder by using a torch, or a soldering iron? I have sweated pipes and I have soldered small wires with a soldering iron, but haven't done electrical with a torch. I suppose I will need a plumber's torch and rosin core solder?
Get a bunch of solder melted in there then shove the wire in? Or put the wire in and solder what you can see?
How can I be sure my truck is a 2/0 wire for when I purchase the flag connector?
Seems like I am going to have to be very careful how I cut the wire or it will end up too short. I wonder if the wire is continous all the way through the existing connector, or if it is two wires coming into it? I was wondering if I could heat it up and pull the wires out.
I use a crimp tool should I be able to get enough leverage on the tool to crimp it with the connector in the truck?
__________________
Alan L., TX
South of Bugtussle
North of Mustang
On the banks of Buck Creek
We don't rent pigs.
Alan L. is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.21005 seconds with 9 queries
