We're planning an addition to the house and will be adding another place to have a washer/dryer. If we locate this in the central portion of the addition, it will be several feet from the nearest outside wall.
I was wondering if it would be possible (or maybe even if it is accepted practice) to install dryer vents under a concrete slab. Our addition will have a concrete slab floor (which is not there yet) and we will be putting plumbing piping beneath the slab anyway. Would there be any issue with adding a duct for the dryer venting?
I have been in homes that had HVAC ductwork in the slab, and I've heard that people aren't too fond of that because of the possiblity of mold or other stuff in vents. However, the dryer vent is just going to be blowing outside. I could run the duct straight so it would be easy to clean out as well (I think).
Any thoughts on material? Would PVC pipe be out of the question because of flammability? I know I see the plastic flexible duct still available, but that doesn't mean its a good idea. I'm afraid that metal ducting would rust and corrode and cause more problems. Maybe flexible metal inside of PVC?
Any suggestions you guys would have would be appreciated. Thanks.
