Results 11 to 20 of 27
10-09-2012, 12:07 PM #11Platinum Member
- Join Date
- Aug 2012
- Posts
- 955
- Location
- Hartford, SD
- Tractor
- Kubota L3400F
10-09-2012, 12:12 PM #12Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Northern Fingerlakes region of NY, USA
- Tractor
- Kubota L3830GST, B7500HST, BX2660
Re: New Home - Recirculating Hot Water
Hence the swing check valve. It has a flapper that swings open and shut (NOT spring loaded) so the water drifting past (as it cools down in the uninsulated pipe) will open it but it cant flow backwards.
That was the thing that the furnace guy stressed, it MUST be a swing check valve or the system will NOT work.
It works very well for us.
Aaron ZIf mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
John Stuart Mill
10-09-2012, 05:11 PM #13Veteran Member
- Join Date
- Dec 2008
- Posts
- 2,380
- Location
- NoCentral MN
- Tractor
- JD 3320 eHydro w/ 300CX Loader
^^This is the type of system tha is being promoted for our new home. A plumber / friend told me this was the real deal. IF we have a circulating problem....then we could always add a circulating pump (doubtfull as our water heater is at the low point in our loop). Also the pump could be put on a timer to save electric. We will have our bathrooms, kitchen, and two laundry areas served by the hot water loop.....so this system sounds like a winner for our needs. Those instantaneous heaters may be good for sink purposes.....but I think the maintainence issues could be a problem over the long pull (?).
Thanks for the responses.3320 eHydro, 300CX Loader & 15 + great attachments
You gotta mine allot of dirt to find a diamond.
10-09-2012, 05:48 PM #14
I took out my 40 gallon water heater in 2004.
I purchased this Bosch on-demand tankless heater and it has performed worry free since.
I located it between my kitchen and laundry area. there is hardly any wait time for hot water even when not being used for days.
but
at the bathroom and shower on the other end of the house there is a wait time to pass all the cold water in the crawl space out of the line to the bathroom.
my unit is a small water heater and is good for
1 shower
2 sinks
1 laundry
1 sink and dish washer
there is a gallon per minute limit as to how much water it can heat.
they make larger units that can handle a shower and sink at the same time.
we time our showers around the laundry time.
seven showers in a row without loosing hot water is nice.
if i had a basement i would install a second for the bathroom.
read up on them
in the coldest part of winter my inlet temerature can get down into the 30's deg f
im on city water but the lines were run too close to ground level. they don't freeze but get very cold.
we still have hot water but not scalding hot in the winter. in the summer i turn the temperature down.
there is no heating water all day long. no circulation lines or pumps.....
the newer units are electronic ignition and have a power vent option also for horizontal discharge i believe.
tom
Attachment 283675Attachment 283676Attachment 283677Attachment 283678Attachment 283679Attachment 283680Attachment 283681
10-09-2012, 05:51 PM #15Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Tractor
John Stuart Mill
10-09-2012, 06:01 PM #16Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Tractor
We actually have 2 HW heaters, a ~40 gallon indirect one that runs off of the boiler and a on demand tankless electric one (44 amps at full load). When we use the indirect heater, the loop works well. When we use the on-demand heater it doesn't work. I have thought of adding a pump on a timer/temp sensor to keep the water at the sink hot at high use times, but that is as far as I have gotten.
John Stuart Mill
10-09-2012, 06:01 PM #17Platinum Member
- Join Date
- Aug 2012
- Posts
- 955
- Location
- Hartford, SD
- Tractor
- Kubota L3400F
I am still doubtfull about any valve working as there is zero pressure differential or in other words nothing to make the valve open and close. Perhaps even without any swing valve the cooler water would settle in the return line and head back towards the water heater. Perhaps this does work but many times what people think does not meet scientific reality. I would like to know why this isn't common knowledge in the plumbing industry as you have an almost perpetual motion machine.
10-09-2012, 06:12 PM #18Super Member
- Join Date
- Mar 2008
- Posts
- 6,497
- Location
- Tractor
If you look at the valve, the flapper just swings back and forth. When I brought it home, it just rattled around
Well, cold water falls, as water cools off, it drifts down the pipe and into the cold water input. I can feel the temperature differential on that vertical copper water pipe, MUCH cooler at the bottom than at the top.
The furnace guy has been working with boilers and furnaces since he was ~10 (according to his stories anyways) and really knows his stuff. He was the first person who could look at my system (wood boiler tied in with oil boiler) and tell me something that I didn't already know about it. If anyone in the area wants his number, I would be happy to pass it on.
John Stuart Mill
10-09-2012, 06:55 PM #19
When I remodeled our house a couple of years ago, the plumber added a thermosiphon line for the master bath. It is on the second floor on the opposite end of the house from the hot water heater in the basement. When you turn on the shower, you have hot water in less than 5 seconds. No pump, works like a charm. This is nothing new. I'm sure people have been installing these for over 50 years.
10-09-2012, 08:27 PM #20Gold Member
- Join Date
- Jan 2011
- Posts
- 437
- Location
- Central, OK
- Tractor
- jd 1050 LS I3040H
Piped properly, the gravity return or thermosiphon piping arrangement will work and alot of plumber install them. The check vavle is more to prevent the hot water from flowing backwards and allowing the piping to get warmer on the return side and causing the system to stop flowing. Many plumbers will not plan ahead far enough to install a working system or the owner / general contractor makes changes that will not allow the system to function properly. Pipe routing is critical.
LS I3040H w/ loader
JD 1050 w/ loader and backhoe
Similar Threads
Creating a home for my Hot Tub
By EddieWalker in forum Rural LivingReplies: 113Last Post: 03-21-2012, 12:40 PM -
Water heater - how hot is too hot?
By adlertom in forum Rural LivingReplies: 32Last Post: 01-14-2008, 12:18 AM -
Recirculating Pumps
By jand38 in forum Rural LivingReplies: 10Last Post: 01-13-2008, 05:42 PM -
Hot water heater is off!
By Doc_Bob in forum Related TopicsReplies: 21Last Post: 07-29-2006, 10:09 PM -
Need more hot water
By ejb in forum ProjectsReplies: 11Last Post: 03-26-2002, 10:30 AM
