Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1
    New Member PalmSprings's Avatar
    Join Date
    Jul 2011
    Posts
    16
    1922 McCormic Deering 10-20
    Default Air compressor troublee shoot question
    it looks like there was no appropriate place for this question,but this is as close as I could come.
    I have a little inexpensive 2hp air compressor .
    I pushed the on button to start it and only got a hum. Of course i only let it hum for a second,so shouldnt be any damage from it.
    It has run for a few years flawlessly,but this particular day it just didnt.
    I took the shroud off to see if I could at least turn the starting motor by hand and retry a start,but couldnt find a way get into it.
    Besides throwing it away an getting a better compressor,how do you suggest I try to see if i can get the moter to start ,provided it only needs a nudge or some other simple thing to check that may be a possible solution?
    Its made by US hardware (made in china) a little cheapie.
    Thx
  2. #2
    bcp
    bcp is online now
    Join Date
    Jul 2009
    Posts
    2,244
    SW WA
    Kubota BX2360
    Default Re: Air compressor troublee shoot question
    Some compressors have a relief valve in the pressure switch so the motor/compressor does not have to start against the air pressure. This may not be working. Try it with no air pressure in the tank or line.
    Bruce
  3. #3
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    13,613
    Tyler, Texas
    Several, all used and abused.
    Sounds like it might be cold. From what I understand, you have to use a cold weather oil that is thinner or it wont start spinning. With mine, I put it out in the sunniest location I can and wait until the last minute to turn it on. Even then, it takes awhile until it works.
    Eddie
  4. #4
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    3,940
    Grants Pass, OR
    JD TLB 110
    Is it an oiled cylinder, or an oilless type?
    Eddie is right that oil-type compressors will not start well in cold weather. Put it away in a warmer location at night or just keep trying starts. It will pop breakers at first, but will eventually run.
    Oilless compressors start better in cold weather, but have much higher noise levels and do not last nearly as long as the oil ones.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  5. #5
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,646
    Nova Scotia, Canada
    Two HP eh ? , check the capacitor.
    Also try starting with the belt off.. If it hums then you know the problem lies in the motor.
    Might try a different plug in on a different circuit??
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  6. #6
    xtn
    xtn is offline
    Join Date
    Apr 2011
    Posts
    575
    New Holland Boomer 50
    Probably not your problem, but worth mentioning just in case: Don't power it through a thin, household extension cord.
    xtn
  7. #7
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,146
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    if this was on an extension cord.. try right into the wall.
    ditto on trying it with no air in the tank.
  8. #8
    Join Date
    Jul 2011
    Posts
    16
    been out of town since my post. will respond tomorrow.
    thx for tips
  9. #9
    Join Date
    Jul 2011
    Posts
    16
    No belt. see pic i posted today
    Attached Thumbnails Attached Thumbnails Air compressor troublee shoot question-dsc05365.jpg   Air compressor troublee shoot question-dsc05366.jpg   Air compressor troublee shoot question-dsc05367.jpg
  10. #10
    Join Date
    Jul 2011
    Posts
    16
    You got me..Capacitor? where? At the start switch? Ill try all the suggestions tomorrow am.
Similar Threads
  1. air compressor question
    By revg62 in forum Build-It Yourself
    Last Post: 09-03-2009, 02:08 PM
  2. Air Tools / Compressor Question
    By tderrick in forum General Vintage Tractors
    Last Post: 06-28-2009, 01:17 PM
  3. Air compressor question
    By jayhaitch in forum Build-It Yourself
    Last Post: 09-24-2006, 10:04 AM
  4. air compressor question
    By snapper in forum Rural Living
    Last Post: 07-31-2003, 12:17 AM
  5. Air compressor question
    By snapper in forum Owning/Operating
    Last Post: 02-11-2003, 09:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
