Results 1 to 7 of 7
  1. #1
    Super Star Member
    Join Date
    Apr 2001
    Posts
    10,744
    NH TC25D
    Default Self Shielding Flux Core Wire Welders
    The Northern Tool Catalog arrived yesterday and I succumbed to the temptation and began browsing through it. I noticed three welders;
    - Hobart Handler 125 Welder for $330
    - Century Models 83073 ($230) and 83096 ($330)
    What caught my eye was the Century for only $230! My welding needs are minor and I don't have the room for a tank of gas, although each of these welders have gas conversion kits for $80.
    They all can weld up to 3/16" steel, which is the thickness of the steel on my front end loader bucket.
    For $330, or even better $230, how can you go wrong? What am I missing? [img]/forums/images/graemlins/confused.gif[/img]
  2. #2
    Join Date
    Jan 2002
    Posts
    856
    South West Pa/Greene county
    Long/Landtrac360DTC
    Default Re: Self Shielding Flux Core Wire Welders
    Mike,
    I would spend the extra $100 and go with the Hobart. I have used a few of the lower end Century models and the wire feed leaves a bit to be desired. It is not as smooth and steady as in the better names like Hobart, Lincoln, or Miller. If you have a local TSC, they carry the Hobart welders, so you could check them out before you buy one.
  3. #3
    Super Star Member
    Join Date
    Apr 2001
    Posts
    10,744
    NH TC25D
    Thanks, Ed. [img]/forums/images/graemlins/smile.gif[/img]
    Any idea how welding goes with one of these units when you don't use the gas?
  4. #4
    Elite Member Tractors4u's Avatar
    Join Date
    Mar 2002
    Posts
    2,542
    Athens Alabama
    Deere 4310, Kubota L355, John Deere SST18 Spin Steer, 2006 Polaris Ranger
    I have a Lincoln Weldpak 100 and I have been very pleased with it. I have welded thin sheet metal successfully and welded heavy duty thick material with multiple passes with great success. I got mine for about $300 + tax at Home Depot. Attached is a project I built with it.
    Attached Images Attached Images
  5. #5
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    Kubota B2710, IH TD6-62 dozer with Drott 4n1 bucket loader
    Be careful when using 110v welders. Always check your penetration. A nice looking weld is not always strong. Practice on scrap first.
    The welders forum is a wealth of good information.
    welders forum
  6. #6
    Join Date
    Sep 2001
    Posts
    707
    Monroe, Va
    Kubota 1997 L3600DT 4WD with FEL
    Wire welding without gas works okay but it is generally known to be less desireable than gas shielded. As a weekend welder what I find a bit ironic is that for occasional light welding, flux wire seems to be a good solution but there is a problem with "freshness". Moisture is very bad for the flux and by moisture I mean humidity. If you use it sporadically it will not stay fresh unless you take carefull measures. Keeping it stored in a moisture proof container helps. Maybe some of the more experienced welders here can offer us all some tips on this.
  7. #7
    Join Date
    Jan 2002
    Posts
    856
    Long/Landtrac360DTC
    <font color="blue"> Any idea how welding goes with one of these units when you don't use the gas? </font>
    I have the gas setup for mine, but I mainly use the flux core. I got the gas setup for welding light, thin stuff (body work on cars). If you plan on welding outside, the flux core is the way to go as the wind can blow the shielding gas away, causing a poor weld. The biggest thing to remember with the wire welders is to have the metal you are welding as clean as possible. With a stick welder, using 6011 rods, you can get away some rust, dirt, or paint on the metal, but with the wire welder, its pretty cruicial to have clean metal. As long as you take the time to clean up the area you are welding, and don't try to weld any thing too heavy, you will do fine with the flux core welder. One final note, for the self learner, it is much easier to learn with a wire welder.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
