Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,406
    central Iowa
    JD 2720
    Default How big is my mixer
    I bought a concrete mixer at a garage sale and I am wanting to know what size and how many bags of Quikrete I could easily put in per mixing. Would it mix two - 80 pound bags at the same time or just one - 60 pound bag? I ask because I have never ran a mixer in my life. I am wanting to make a 240 pound weight for my lawn aerator and figured someone here has ran a mixer like this one and knows what size bag will fit the best.
    The inside dimensions of the tub are;
    21" diameter at the widest spot
    24" deep
    14" at the opening
    How big is my mixer-20150908_151708_resized-jpgHow big is my mixer-20150908_153256_resized-jpg
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  2. #2
    Super Member 4570Man's Avatar
    Join Date
    Apr 2015
    Posts
    5,545
    Crossville, TN
    Kubota L3240, Kubota B7100, Kubota F2560, John Deer, F525 Mule 600
    Default
    I have a mixer that looks very similar. It will mix four 60 pound bags, but it is easier to dump with just 2.
  3. #3
    Join Date
    Feb 2006
    Posts
    3,406
    central Iowa
    JD 2720
    Default Re: How big is my mixer
    I imagine when 4 - 60 lb bags get past the tipping point on the way out that it would just slam down onto the stop. Maybe even tipping its self and the wheelbarrow over. That first load could flatten out a large learning curve.
    HAVE FUN
    2720
  4. #4
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    the concrete mixer i have. looks approx same size. i generally do not over load it, due to wanting to keep all the slop of concrete/water mixing inside the unit, and not a big mess around it. along with using wheel barrows to 5 gallon buckets. not wanting to have to lift / move a couple hundred lbs of concrete at a time. so generally it goes between 1 to 2 80# lbs of concrete.
    it takes practice getting correct amount of concrete / water mix ratio. when you are physically troweling it on say concrete block wall, to making a little sidewalk or a little pad to set something on a concrete pad. to wet or to dry = more difficulty in applying the concrete.
    mixing concrete and dumping it down say a hole for a post is one thing. but everything else it does take some practice. keep it in smaller batches say 1 to 2 bags at a time. and only mix enough that you can use in a short amount of time.
    be careful of fiber concrete... the fiber can tear up your skin / hands pretty quickly. (make sure you wear rubber gloves), also just general concrete make sure you wear gloves and keep concrete off your skin. folks can get what is known more like "concrete poisoning" i don't remember correct term, but the concrete soaks into your skin and can mess you pretty badly.
    for a 240 lbs concrete weight for tractor.... 60# lbs bags to 80lbs bags... does it really make a difference? mix a bag at a time and get a feel for how to mix concrete and learn the unit. so when you get on other projects, you are not experimenting as much to learn about how to mix concrete. ((obtaining a better water / concrete mix ratio))
    Ryan
  5. #5
    Join Date
    Feb 2006
    Posts
    3,406
    central Iowa
    JD 2720
    I think i'll buy 60 lb bags, they are easier to handle and it sounds like 2 at a time might be just about right. I will be trying for a 5" slump or less.
    HAVE FUN
    2720
  6. #6
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,675
    Nova Scotia, Canada
    Fill it with water. That should get you a volume.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  7. #7
    Super Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    6,941
    FWIW...mixing and pouring concrete using bagged products or with fine and course aggregate and portland...is fine...but...if the pour is going to be exposed to freeze/thaw conditions an air entraining agent should be added to every batch. https://en.wikipedia.org/wiki/Air_entrainment
    Also, for many projects the bagged concrete etc. mixes are OK as is...but for more durability and strength it is recommended that additional portland cement be added...
    Slash Pine
    blunt and succinct yet sincere I don't suffer fools or thin skinned neanderthals...in the immortal words of Popeye..."I yam what I yam"
  8. #8
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,641
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by boggen View Post
    Yeah, that's good advice. Such a tiny pour could be done in a wheelbarrow with a hoe.
    I prefer the 60# high-strength bags myself, and I recently poured my swale bridge. Note that
    a 60# bag is half a cubic foot. Wet, it will be about 75#, so only about 3 bags will be needed
    to reach 240#. Add some gravel to make up the slight shortfall.
    In this photo, I am pouring about 5 bags at a time, at about 0 slump. I can do as much as
    8 bags (4+cf) at a time with this mixer, no way near the 8.5 cf it is quoted to handle. Even 5
    60-pounders, wet, is gonna be close to 400# at a time.
    Attached Thumbnails Attached Thumbnails How big is my mixer-pouring_concrete-jpg
  9. #9
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    Quote Originally Posted by dfkrug View Post
    that is called cheating, using FEL with mixer attached to it! *laughs hard*
    nice setup!
    Ryan
  10. #10
    Join Date
    Apr 2015
    Posts
    5,545
    Crossville, TN
    Default
    I buy 60 pound bags. They are even cheaper per pound than an 80 pound bag.,
Similar Threads
  1. Big Cat Concrete mixer
    By Nat in forum Related Topics
    Last Post: 07-20-2015, 05:23 PM
  2. Replies: 30
    Last Post: 03-09-2014, 11:15 PM
  3. 3720 Finish (Pull Behind) Mower - How big is too Big?
    By morrisond in forum John Deere Buying/Pricing
    Last Post: 06-12-2012, 01:15 AM
  4. Riding Big-Boy's big brother
    By richardbro in forum Owning/Operating
    Last Post: 10-15-2007, 12:52 PM
  5. Mortar Mixer and Concrete Mixer RPMs
    By Pooh_Bear in forum Build-It Yourself
    Last Post: 05-15-2006, 02:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
