crafty
I have not been on this board for quite some time, if my post is redundant in comment and complaints I apologize. I was wondering if anyone else has had similar exerperiences to mine. if so have you resolved them or do you still spend more time at the dealership then driving.
I have been a long time fan of Chevy trucks, I have owned about 10 in my 16 years of driving. I have never had so many problems with a vechile until my '99 1500 5.3 z71. I have 37000 miles worth of grief:
1)The rear disks had to be replaced at 500 miles
2. Sliding window had to be replaced 6 times due to water leaks.
3. On the fourth transfer case (only used when pull the trailer with 4 quads out of the back yard about 2000lbs total)
4. Computer has been flashed over 6 times to update the shifting, timing, "fix the pining" which I still have.
5. Door hinges squeaking terribly.
6. Brake Master cylinder defective replaced twice.
7. Steering shaft replaced three times still rattles.
8. brakes are soft, pads look good, pedal hits floor dealer said it is normal.
9. Daylight running passenger side lights replaced monthly.
10. Put 600 lbs of crushed stone in the bed which sank the ass end 4 inches now the rear end bounces traveling down the highway, so much for the idea of a half ton.
11. on the fourth trannie dealer said I should put a trannie cooler on since I'm overhearing it with the quads/trailer, (I do wood working/cabinet making as a hobby) pulling the wood shop (3500lbs) and the camper (4100 abs). I asked the dealer if he meant in addition to the factory cooler and what exactly I was doing beyond the capibilty of the truck. thier response was a shoulder shrug.
12. third rear axle seals keep blowing out.
13. second throttle body gas pedal still sticks.
any comments appreciated.
