Results 1 to 10 of 10
  1. #1
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    Default Repairing a stone wall
    This part of the wall has been bugging me for 2 yrs now - we're putting in a goat pen on this side of the wall, and I figured they would knock down the rest of it eventually if I didn't do something about it.
    Attached Images Attached Images
  2. #2
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    Default Re: Repairing a stone wall
    The wall was built as an inner and an outer wall, with rubble stones and dirt filling in the gap, and the top capped off. That stump probably didn't help, and the rest of the damage is freeze/thaw problems brought on by cracks in the mortar up top.
  3. #3
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    First I repointed the inside of the wall to hold it up (it's only bowed at little), then I tore the loose stuff off the outside. It's on the way back together here.
  4. #4
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    Getting there....
  5. #5
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    Done! I filled this section back up with stones and bags of dry concrete, then sprayed it with the hose.
  6. #6
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    Last one - top view. My mortar color isn't quite what I'd like it to be, but I didn't have time to match it. It will mellow with time some.
  7. #7
    Join Date
    Feb 2003
    Posts
    1,121
    Thurmont, Maryland
    TC35D w/ SS
    I was wondering if your wall was a foundation for a building in the past?
  8. #8
    Join Date
    Mar 2005
    Posts
    276
    Northern Panhandle of Pennsyltuckey
    Kubota B7610 TLB & MF 253
    Nice job.
    I've a smaller wall that needs similar repair.
    Bought a bag of mortar about 3 yrs ago, but that's as far as I"ve got. [img]/forums/images/graemlins/frown.gif[/img]
    Thanks for the inspiration.
  9. #9
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    No, it's a farily standard (for this area) barnyard wall. Most old barns in this area had them, although many have been torn down, or just collapsed into a pile of rubble. Given that it is essentially hollow, which I didn't fully realize until I tore into it, I don't think it has the strrength to be a foundation. The walls in the local stone houses are not hollow, at least not the ones I've worked on. I have lots of other areas on it that need new mortar too, and I'll have to get to that soon.
    I'm thinking it may have been gone over once in the past, perhaps in the 1950's when the house was worked on too, but I can't be sure.
  10. #10
    Join Date
    Feb 2004
    Posts
    655
    Hereford, PA
    LK3054
    Thanks - it's kind of enjoyable when you get going, and you can do it a bit at a time. You kind of have to really, as it gets touogh piling more heavy stones on top of the lower ones when they have not set up yet.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
