Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Elite Member czechsonofagun's Avatar
    Join Date
    Jun 2006
    Posts
    3,381
    Old Dominion
    Kubota B1750
    Default Loading logs
    I have few nice maple logs on the ground I would like to get to the sawmill. About 15" diameter, 12 feet long. My trailer would handle the load, my problem is how to get it up.
    I dont have a front loader, the tractor is only 20hp kubota, I dont think the 3pt would be up to it.
    My plan as of now is to build simple gantry and hang a hoist from it, lift one end of the log, backup the trailer under and lower the log.
    Opinions? Ideas?
    Thanks
    Prokop
  2. #2
    Veteran Member gordon21's Avatar
    Join Date
    Feb 2006
    Posts
    1,005
    Lake Lure NC
    JD 790
    Default Re: Loading logs
    Can you put a floor jack under the log about 4' in from the end? You would have to dig out an area to slip the jack underneath and put a 2x8 scrap under it for stability. If you could jack the log up 10" at that point, the end would raise 15" Would that be enough to slide it onto the trailer you have?
    I think you are underestimating your tractor. Attach the 3pt approx 4' from the end like the above suggestion. All you need to do is lift the log straight up 10-15" off the ground at that point to get 15-20" elevation at the log end. You then back the trailer under the high end. You are not lifting the entire log's weight. Most of the weight is still dead weight resting on the ground. With the tractor at a 90 degree angle to the log 4' in from the end, you can still get the trailer close enough to load the end.
    Nothing to build. All you need is some chain.
    Lewis Gordon
    JD 790, 300 FEL, 5' KK rotary mower, 5' boxscraper, Huskee 3PT logsplitter, JD#39N sickle mower and a Jinma 6" chipper in JD colors.
    My XUV gas Gator wants a brother !!!!!!!! (the diesel kind)
  3. #3
    Join Date
    Apr 2002
    Posts
    2,086
    SW Ohio
    yanmar
    If your trailer is flat (no rails), load from the side. Lay two or three 2x6 or such against the trailer, roll the log to the bottom of the boards, while getting a sturdy rope or chain around it. Hook to your tractor on the other side of the trailer and slide/pull them up the 2x6s...nail a 4x4 or such to the trailer floor to keep them from rolling across and off the other side.
  4. #4
    Join Date
    Jun 2006
    Posts
    3,381
    Old Dominion
    Kubota B1750
    Chain I got, I am gonna buy Tractor Supply Company - BOOM POLE and give it a shot. It is much easier than building a graple.
    Thanks
    Regards,
    Prokop
    I was put on Earth to accomplish a certain number of things. Now I'm so far behind, I'll never die!
  5. #5
    Gold Member
    Join Date
    Jan 2006
    Posts
    354
    NORTHWEST MICHIGAN
    KUBOTA L175
    I have a kubota L175 ( about 17 horse ) and have used the boom pole with pretty good luck. You may need to lift just one end of the log and swing it on to the trailer, then do the other. I've moved some logs that way when the tractor would not lift the whole thing. Also, you may need to hook the chain part way up the boom pole- less leverage,but you won't left the front end of the tractor, and you can left more weight that way. good luck, and watch your hands!
    In my pre tractor days I would make a ramp up to the side of my trailer with 4x4's and roll them up. A come-along may work, but sometimes the trailer would move instead of the log! Cant hook and muscle seemed the best. Gotta watch the log doesn't roll back on you.
  6. #6
    Join Date
    Jun 2006
    Posts
    3,381
    Old Dominion
    Kubota B1750
    LMTC the trailer is a box, end gates are hinged on the bottom, I have to slide it in from the back.
    Goaliedad thanks for the shared experience. If I take baby steps I am sure I will get it done.
    Attached Images Attached Images
  7. #7
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,726
    Nova Scotia, Canada
    Put down a plywood ramp and use a come along.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  8. #8
    Elite Member
    Join Date
    Jan 2002
    Posts
    4,713
    SE Wa
    Quote Originally Posted by LMTC
    Works great especially if you fasten one end of the chain to the trailer, run it under and then back over the log to the other side of the trailer. When you pull, it rolls the log up the ramp. That was one of the techniques used back in the pioneer days.
    Harry K
  9. #9
    Veteran Member BTDT's Avatar
    Join Date
    Sep 2006
    Posts
    2,209
    North Texas
    IH M Farmall-propane powered, H Farmall (father-in-laws), Ford 1300 diesel
    Set your vehicles up like this. Use tractor to pull log up onto round fence post, then pipe, then barrel. It should roll right up into trailer. Might put pipe in bed of trailer to allow to roll easily to front.
    Attached Files Attached Files
    Praise is not something you do to get closer to God, praise is a response to God being close to you.
  10. #10
    Join Date
    Jun 2006
    Posts
    3,381
    Old Dominion
    Kubota B1750
    Quote Originally Posted by BTDT
    Interesting, thanks. I will definitely give it a try - as soon as the log unfreezes from the ground.
    I had also this vision of 2" hitch in the front bumper, hook up the trailer to it and get an off road winch on the front bumper. Similar setup exists for flat bed tow trucks.
    Regards,
    Prokop
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
