Wood stove problem.
   / Wood stove problem. #1
JSUnlimited
Ohio
New Holland
The main firebox door on my add-on wood furnace has developed a small hole. It is a cast iron door. Can it be fixed? I'm probably going to either have a new door fabbed or order a new one. Just wondering.
The hole is located between the L and the A as indicated by the pics.
   / Wood stove problem. #2
Must have been a bad cast. I would just weld it up
   / Wood stove problem. #3
Most wood stove companies including my Hearthstone will have a lifetime warranty on cast iron parts unless it can be shown that the failure was due to overfiring. I would send the photo to the manufacturer (Clayton) as it appears to be an obvious casting defect.
Otherwise, braze in some filler or maybe even JB weld.
   / Wood stove problem. #5
You cold also drill it out and put a decorative bolt in it.:D
   / Wood stove problem. #6
Or you could machine out the middle and put a glass door in so you could watch the flame.
   / Wood stove problem. #7
welding cast is tricky at best.
best bet is braze if you cant get the warneete thing to go through.
   / Wood stove problem. #8
You need to be a little careful if you do this.
Common nuts & bolts are cadmium plated. Surprisingly, Cadmium has a fairly high vapor pressure and in a high temperature application will release Cadmium vapors.
Cadmium is also pretty toxic. The poisoning is very painful and is not reversible.
I would highly recommend either a stainless bolt, or an unplated one for a stove in a living room.
   / Wood stove problem. #10
Comeon now, how many bolts, nuts, or studs have you welded on and not died from cadmium poisoning?
10' CONTAINER (A51248)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
