Shimon
I'm fixing some fencing and putting in some H-braces in the corners. They will be 8' 6" vertical PT round posts with 8' 4" horizontals. I've usually just double wrapped some 9ga wire and twisted the wire using a twitch stick (as shown in the first photo).
I bought some of those Rapid Wire Tighteners from Gallagher and want to use those. Anyone use these before?
Should I wrap the wire around the posts with only one strand going between them so that only one strand runs through the Wire Tightener? Or should I still loop the wire around both posts so that there are two or four strands of the 9ga wire between the two posts and run them all through the Wire Tightener?
Only thing that concerns me is having an opening near the ground near the corner post where an animal can get it's leg caught between two wires coming out from either side of the corner post. I was thinking of tying the wire around the corner post with a knot as shown in the second photo so there isn't any opening down there. Will a knot weaken the wire?
Hope this makes sense.
