Results 1 to 5 of 5
  1. #1
    bjr
    bjr is offline
    Join Date
    May 2005
    Posts
    803
    Eastern WA
    Jinma JM354
    Default 100 Gal. Propane tank leak check
    I just bought a used empty 100 gal. tank (I think it's called a Jug tank). I want to put like 30# air in it and soap suds the valves to make sure nothing is leaking. Will this be okay? Will it need purging or something for the air I put in it? thanks. bjr
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,709
    Nova Scotia, Canada
    Default Re: 100 Gal. Propane tank leak check
    Maybe give some more information.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  4. #3
    Elite Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    4,628
    The Heart of Dixie
    yanmar 3110D
    Don't know about straight air. I would use nitrogen
  5. #4
    Veteran Member WayneB's Avatar
    Join Date
    Oct 2006
    Posts
    2,230
    New Hampshire
    Kubota B-7500
    SORRY ABOUT THAT, I MISSED READ YOUR POSTING AND THOUGHT YOU MEANT A 100 POUND TANK. A 100 GALLON TANK WOULD OR SHOULD BE CHECKED BY THE PROPANE COMPANY. I AM SURE THEY WOULD DO THAT FOR YOU BEFORE FILLING IT UP.
    Not that I ever tried what you are attempting, but I do have several 100 Pound tanks and have them filled at the local hardware store. They will take a tank and fill it with approximately 23 gallons of liquid propane. I am pretty sure that you could take a tank that you put regular air into and it would be purged out when they fill the tank.
    The old soapsuds trick might work (I have used it to check connections in the past), but I am not sure if I would trust it or not? I would think you could construct and fixture so you can place a pressure gauge you screw into the outlet fitting. Once attached open the valve and check what the pressure is in the tank. If it holds pressure for a period of time, then I would say the tank isn't leaking.
    Suggest you call someone that fills tanks and ask them what to do. They might even inspect the tank for you.
    Another thing you could do is to take it to a place where they swap out tanks. TSC does it, but the cost of their tanks is higher than what it cost to have a tank filled, but doing it this way you will end up with a newer tank and the worries go away. They will check the bottom for rust and the tank for dents and what have you, but the 100 pound tanks are not required to have the new type of fittings so your old tank could be swapped out.
  6. #5
    bjr
    bjr is offline
    Join Date
    May 2005
    Posts
    803
    Eastern WA
    Jinma JM354
    I finally got thru (was put on voice mail several times with no return calls) to two different propane service techs and for that size (100 gal) they said to go for it. They could purge the tank or put in some kind of chemical additive (they told me and I just don't remember what it was called) to take care of any moisture. They like to see tank fittings soap tested and they do their own testing and inspections as well. This is not the same as the smaller portable tanks most people use for their BBQ's and have different testing standards. I use mine for a fireplace. I did my testing with 30# air and found no leaks and feel a lot better about calling for a fillup. Now, I know. bjr
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
