Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 62
  1. #21
    Veteran Member JohnDeere4300's Avatar
    Join Date
    Feb 2005
    Posts
    1,564
    Eastern, Kentucky
    John Deere 4300
    Default Re: Wood Stove Rebuild
    Nice wood stove Lloyd!
    How long have you used it to get a hole like that ?
    And also, what kind of wood do you burn ?
    John 3:16
    01 JohnDeere4300 "Sync-Reverser", Vertical Exhaust, 2 JD Lawn Tractors, JD Walk Behind.
    430-FEL/ 47-Backhoe/ 5' Bush-Hog/ Single Bottom Plow/ 6' Disc/ 60'' Tiller/ 72'' Rear Blade/ Aerator Spreader/ HF Quick-Hitch!
    (Homemade Stuff) BH Thumb/ Log-Hitch/ 10' Boom-Pole/ 42'' Pallet Forks ''FEL Quick Attach & 3PH Quick-Hitch-Attach''/ Ballast Box 1381 lbs./ Aluminum Canopy/ Brush-Guard Mod/ 5x10 Firewood Trailer/ Lawn Striper.
  2. #22
    Veteran Member Lloyd_E's Avatar
    Join Date
    Nov 2003
    Posts
    1,335
    South Shore Nova Scotia Canada
    2008 Kioti DK 45 sc
    jd and irving,
    I bought the stove used. It says 1979 or it did before the hole occurred. I've used it for 8+
    years. I noticed a crack last year and tried to weld it. That held for about 6 months. This past winter the back cracked in several places and a chunk fell out. I used it for about 3 months with the hole. It is a baffle and not the back of the stove.
    A new back was ordered and arrived during the burning season. I burn everything from oak, birch and hemlock to pine. The softwoods are used to start the fire. I mostly burn oak - well aged - at least two years. I keep a watchful eye on the thermometer on the stove pipe and burn within the desired ranges.
    I just got back from the hardware store with new gaskets and 4 tubes of 1035f stove cement. So I will be wire brushing the parts today and assembling later with the help of a friend.
    Will post pics of reconstruction.
    lloyd
    Work hard to get it down - play like tomorrow may end!
    Small Horse Farm: 12.5 acres: 2008 Kioti Dk 45SC with Cab, FEL, BH, 6' snow blower, 7' back blade, 7' box blade, 6' bush hog, 9"& 14" auger, 8' chain harrow, 4" chipper, sand spreader, 7' landscape rake, 3pt quick attach & coffee holder.
  3. #23
    Elite Member scott_vt's Avatar
    Join Date
    Oct 2004
    Posts
    4,928
    east wells,vt
    1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
    Good Evenin Lloyd,
    Wow thats a big job, now I see why you waited for the end of the burning season last year !
    Good luck with the reassembly !
    scotty
    ,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
    http://www.tractorbynet.com/content/...onth-scott_vt/
  4. #24
    Join Date
    Nov 2003
    Posts
    1,335
    2008 Kioti DK 45 sc
    So, It's back together - ya!!!!!!!!!!!!
    I wired brushed everything and chipped out old cement. The rebuild took two tubes of stove cement. I used stainless nuts and bolts and reversed them for clearance - bolt head inside - nut outside.
    I did a dry fit before laying in a bead of cement. The biggest challenge/time concern was lowering the top and aligning the four corner rods. The rods go from top to bottom and bolt at the bottom. They were in decent shape so I left them - I didn't want to break a rod threaded into the top part of the stove. Once the cement dries it will add extra strength to the stove.
    I laid a bead of cement everywhere I could and once the stove was together I laid a bead on the outside where the stove plates came together. I also put a new gasket in the top. I ended up putting it together by myself - but two people would be better.
    Tomorrow I will use stove black to give the stove a 'new' look and move it back into the house. Doors and side shelves will go on once it is in place.
    lloyd
    Attached Thumbnails Attached Thumbnails Wood Stove Rebuild-img_4383.jpg   Wood Stove Rebuild-img_4384.jpg   Wood Stove Rebuild-img_4385.jpg   Wood Stove Rebuild-img_4388.jpg   Wood Stove Rebuild-img_4389.jpg
    Wood Stove Rebuild-img_4390.jpg   Wood Stove Rebuild-img_4392.jpg   Wood Stove Rebuild-img_4393.jpg   Wood Stove Rebuild-img_4395.jpg   Wood Stove Rebuild-img_4396.jpg
  5. #25
    Join Date
    Oct 2004
    Posts
    4,928
    east wells,vt
    Good Evenin Lloyd,
    Very nice !!!
    I see you use the angle grinder with the braided wire wheel also !
    scotty
  6. #26
    Join Date
    Feb 2005
    Posts
    1,564
    Eastern, Kentucky
    John Deere 4300
    Great job Lloyd!
    Glad you were still able to get parts for you stove.. For the stove to be made in 1979 it sure has held up great.
    Right now I'm installing a new wood stove.. United States wood stove, and it connects into my duct-work of my home.
    I burn a lot of oak also..This year I was able to cut up a couple of beech trees that fell from an ice storm we had early this year. I have never burned beech before, and they say it will put out great heat.
    Glad you got your stove back together! and Thanks for sharing you work.
    John 3:16
  7. #27
    Join Date
    Oct 2004
    Posts
    4,928
    east wells,vt
    Quote Originally Posted by johndeere4300 View Post
    Good Mornin Bill,
    The local farmer let me take a beech tree that had come down in a storm last year, I think you will like burning beech !
    Its a great heat source !
    scotty
  8. #28
    Join Date
    Nov 2003
    Posts
    1,335
    2008 Kioti DK 45 sc
    I burn beech and poplar too. You'll find both east to slit... straight grain.
    There is a saying about types of wood - which I am trying to find - and it is either poplar or beech that burns the eyes from smoke.
    lloyd
  9. #29
    Elite Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    4,662
    62014 IL (outside STL MO)
    New holland TC(33)
    Quote Originally Posted by Lloyd_E View Post
    lloyd
    ya but if you have smoke coming from your chimney your not burning right. A properly burning good wood stove (like that vermont casting) should burn nearly perfectly clean. (non-catalytic-converter type)
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  10. #30
    Join Date
    Nov 2003
    Posts
    1,335
    2008 Kioti DK 45 sc
    Clean smoke...
    It's an old poem or saying... may be Thoreau. But basically talks about the different qualities of wood.
    Lloyd
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
