Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 62
  1. #31
    Veteran Member JohnDeere4300's Avatar
    Join Date
    Feb 2005
    Posts
    1,564
    Eastern, Kentucky
    John Deere 4300
    Default Re: Wood Stove Rebuild
    Quote Originally Posted by scott_vt View Post
    Good Mornin Bill,
    The local farmer let me take a beech tree that had come down in a storm last year, I think you will like burning beech !
    Its a great heat source !
    Morning Scott,
    Thanks for the info on the beech!... If beech puts out a lot of heat and you burned a lot of it, then it might burn a stove up quicker ?....Is that right ?
    I have only 11 more big beech trees on my property, and that's where I kill most of my squirrels. ... One thing about most of the 'beech trees' around here is, most of them are hollow.
    Quote Originally Posted by Lloyd_E View Post
    I burn beech and poplar too. You'll find both east to slit... straight grain.
    There is a saying about types of wood - which I am trying to find - and it is either poplar or beech that burns the eyes from smoke.
    lloyd
    Morning Lloyd,
    Back in the spring me and my father-in-law cut 14 very large poplars that were over 70ft. tall, and we had to cut on both sides because a 20in. bar wouldn't go all the way through...and we cut 2 large sycamores that were as tall & round as the poplars.
    We cut these trees because they were too close to my home... I had to build 2 large woodsheds that are 12ft high on one end, and 10ft high on the lower end.. and they are 16x16... I have the wood stacked from the bottom to the top. .. and I had one row that fell over. ... Just glad I wasn't next to it. ... I still have 2 large trees on the ground that needs cut up & split.
    Now I have burned 'sycamores' before and that type of wood puts out good heat too.
    I didn't know about the smoke from certain trees that would burn your eyes.
    John 3:16
    01 JohnDeere4300 "Sync-Reverser", Vertical Exhaust, 2 JD Lawn Tractors, JD Walk Behind.
    430-FEL/ 47-Backhoe/ 5' Bush-Hog/ Single Bottom Plow/ 6' Disc/ 60'' Tiller/ 72'' Rear Blade/ Aerator Spreader/ HF Quick-Hitch!
    (Homemade Stuff) BH Thumb/ Log-Hitch/ 10' Boom-Pole/ 42'' Pallet Forks ''FEL Quick Attach & 3PH Quick-Hitch-Attach''/ Ballast Box 1381 lbs./ Aluminum Canopy/ Brush-Guard Mod/ 5x10 Firewood Trailer/ Lawn Striper.
  2. #32
    Elite Member scott_vt's Avatar
    Join Date
    Oct 2004
    Posts
    4,920
    east wells,vt
    1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
    Quote Originally Posted by johndeere4300 View Post
    Morning Scott,
    Good Mornin Bill,
    Nahh it doesnt burn that hot... there is only one type of wood around here that you really have to be careful with, and thats hardach. That stuff puts out an incredible amount of heat.
    A friend of mine made the mistake of loading up his stove with hardach, the stove got so hot, the whole stove was literaly glowing, he swore that he could actually see through the side of the stove, maybe a slight exageration on his part !
    Anyways, I will only put one piece of that in at a time, and mix in some other stuff...
    scotty
    ,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
    http://www.tractorbynet.com/content/...onth-scott_vt/
  3. #33
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,221
    What kind of stove paint did you use to repaint the exterior?
    Is there a generic source for firebrick for wood stoves?
  4. #34
    Veteran Member Lloyd_E's Avatar
    Join Date
    Nov 2003
    Posts
    1,334
    South Shore Nova Scotia Canada
    2008 Kioti DK 45 sc
    2 many,
    Paint is stove black. You can buy fire brick and stove black from most hardware stores. There is a lighter version of brick that you can cut with a hacksaw or recipe saw.
    The stove black can be brushed on and wiped or buffed with a clean cloth. It is black and messy, stains clothes and hands...
    lloyd
    Work hard to get it down - play like tomorrow may end!
    Small Horse Farm: 12.5 acres: 2008 Kioti Dk 45SC with Cab, FEL, BH, 6' snow blower, 7' back blade, 7' box blade, 6' bush hog, 9"& 14" auger, 8' chain harrow, 4" chipper, sand spreader, 7' landscape rake, 3pt quick attach & coffee holder.
  5. #35
    Join Date
    Feb 2005
    Posts
    1,564
    Eastern, Kentucky
    John Deere 4300
    Good Mornin Bill,
    Evening Scott,
    Never heard of that type of wood.... He could see through the side
    So that would burn A LOT hotter than coal.
    John 3:16
  6. #36
    Join Date
    Oct 2004
    Posts
    4,920
    east wells,vt
    2 many,
    lloyd
    Good Mornin Lloyd,
    Yeah, and that stove black doesnt come off easily either , you kind of need to wear it off !
    Evening Scott,
    Good Mornin Bill,
    Well thats the story I got !
    scotty
  7. #37
    Join Date
    Feb 2005
    Posts
    1,564
    Eastern, Kentucky
    John Deere 4300
    Good Mornin Lloyd,
    Good Mornin Bill,
    Morning Scott,
    Well I know.... That's the story and your sticking to it. ... Now my father-in-law told me yesterday when we was hooking up my stove, that he burned beech wood once and his pipe turned cherry red.
    I tried to do a search on "hardach wood" & couldn't find anything.
    About the stove paint... Let it wear off would be like getting stain from hulling walnuts. ... It stayed on my hands for weeks one time.
    John 3:16
  8. #38
    Super Member Highbeam's Avatar
    Join Date
    Feb 2005
    Posts
    5,035
    South Puget Sound, WA
    Kioti CK30HST
    Thanks for the great pics on the rebuild.
    Kioti CK30HST, FEL w/toothbar, 60" RC, 60" BB, PJ 10k trailer. Weekend warrior hauling 50 miles each way.
  9. #39
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,787
    Central New Hampshire
    Kubota B3030HSDC
    Only wood I've heard of burning that hot is hedge (osage orange), but it doesn't grow around here. Best firewood in these parts is locust...... but i can never get my hands on any. I'd like to find a bunch to compare to my red oak.
  10. #40
    Join Date
    Sep 2009
    Posts
    1,530
    The County, ME
    Kubota M5640SUD
    Hi Lloyd,
    I recently purchased a used VC Resolute III model 0043. It needs a new right insert and lower fireback. I found a few places online that have the parts and so I started to try to remove the old worn out plates. There's a VC PDF doc ont the VC website that provides replacement instructions:
    http://www.vermontcastings.com/catal...ck_Replace.pdf
    I spent the better part of a day tapping and prying, I used lithium grease and soap between the plates but neither plate will come out.
    I noticed from your pics that you removed the bottom of the stove which appears to provide another angle of access to the plates. Did you find the plates came out easily when the base of the stove was off?
    I didn't want to go that far with it but I suppose if it's the only way to get the plates out I'll do it.
    Any comments or suggestions?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
