Planting Taters
   / Planting Taters #11
hunterridge, there are sweeps for bedding also. Never used them but they may work fine. Would think you could also use two middle busters for cultivators and get good results. Also "buzzard wings".
If you have a Agri Supply neay by good price compared to most other stores. Also they stand behind what they sell.
   / Planting Taters #13
You are going to want to hip the soil onto the plants as they grow, this provides more soil for more potatoes to grow in. Around here everything is flood so they add hippers to the 'toolbar' when they cultivate for weeds and to maintain the furrows. You can do it by hand with a hoe but for an acre of spuds it might take a while :D
Maybe grow an alternate crop this year like winter squash until you get set with the right stuff to make 'taters easier?
   / Planting Taters #14
I plant an average of six acres of potatoes per year.
I use a machine to cut the potatoes, but the theory is the same if you cut them by hand or machine. I have planted them right after cutting or leaving them set a couple of days. I have experienced no difference in the final result using either method.
I also use a potato planter and harvester. The planter drops the potatoes down and then creates a small hill over them. I then lay drip line down over this small hill and hill them with a one row cultivator with discs attached which creates a larger hill. I leave this attachment on and continue to hill them when cultivating them later. The disc attachment works quite well and could be fabricating quite cheaply. Attached is a picture of the one row cultivator with the discs for the hilling along with the drip line layer.
According to the information that I have been told is that you can cultivate the potatoes up until the time that they are blossoming. This is to avoid damaging the tubers in the ground. This can vary according to the weather conditions as I have had some fine potatoes with very little blossoming. The same conditions would apply for hilling as cultivating.
I do not use fertilizer on my potatoes. The experience that I have had is the amount of water that the plants receive. This is quite evident in the amounts and when the moisture has been received in the last couple of years. The first year, we had excellent growing conditions and I tossed about ten thousand pounds after planting the next spring.
The amount of seed required per acre of potatoes can range from one thousand to fifteen hundred pounds, depending upon the density and size of the seed pieces.
   / Planting Taters #15
Like with many posts of this kind we see practices vary from locale to locale.
As for hilling, you may have all the equip you need (maybe with a little mod.) The tiller for the Yanmar has a cut out center section on the drag flap. With the cover removed and with some rearrangment of the tines if I choose, the tines move the soil towards the center and a hill is formed with every pass.
I don't grow spuds any longer as it was too much effort due to the gopher problem we have from time to time.
   / Planting Taters #16
Dumbdog, what kind of harvester do you have? Is it one of those conveyor belt looking machines that separate the taters from the soil?
Your planter looks like a standard cultivator with a couple of discs attached. Is that all there is to it?
   / Planting Taters #17
The potato harvester is made by US Small Farms out of Wyoming. It has a PTO operated pump which operates a chain set up that bounces the dirt and potatoes to the end which takes out most of the dirt and drops the potatoes off of the end.
This is a link to the people that manufacture the harvester. US Small Farm - 1-Row Potato Diggers
The picture shown is of the potato hiller attached to the cultivator with the drip line attachment.
Attached is a picture of the planter.
   / Planting Taters #18
Attached is a picture of the potato cutter in action.
   / Planting Taters
Afternoon Guys,
I have been away a couple of days on a sales trip and did not have time to get online.
You have given me alot to think about. I may cut back to 1/2 ac this year...just depends.
Dumbdog I have a single row culti I can add the disc to. I also have another implement I can add them to. I will check TSC and a couple of local feed and seed stores to see if they have the disc like you have on your cultivator. I feel sure TSC has them.
kt, I don't have an Agri Supply close by, they are all on the eastern side of NC.
   / Planting Taters #20
Discs are the easy items to find, it is the attachment portion that is hard to find. The whole assembly is available from US Small Farms in the link that I provided above. If I remember correctly, the cost is about $200.00.
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
