IH3444
- Joined
- Jan 10, 2004
- Messages
- 2,065
Washington Times - RFK Jr.: Hog farms bigger threat than *****
Sounds like he is looking for a quick buck.
On the other hand I don't like these pig factories as they exist in NC. They are not a small farm with a few pigs. They are large businesses with thousands of pigs. Each pigs is supposed to pee and poo as much as four people. Where does the pee and poo go? Into a "lagoon." It ain't blue either. To remove the pee and poo they spray it on their fields. The "farms" have been caught spraying with saturated soil conditions which means the pee/poo mix is just running off into streams and rivers.
Can you imagine a town built on a hundred acres or so with 4,000 people. AND not sewage treatment other than a "lagoon" and spraying pee and poo? Do you want that as a neighbor? Some of these "farms" have 10,000 hogs which is same amount of pee and poo from 40,000 people.
The smell from these things is horrendous. One of the "farms" was build near my FIL. If they are spraying the pee/poo and the wind blows towards his house you don't go outside. And they like to sit outside. But they can't sit outside if the farm is spraying even thought the "farm" is a few miles away.
What happens to your property value when a factory pig farm moves into the 'hood?
Later,
Dan
Later,
Dan
