Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 67
  1. #31
    Join Date
    Jan 2009
    Posts
    965
    Default Re: Building a gun range, suggestions?
    Thats about 800 yds or more,I wouldn't even complain over that if I was your neighbor!I envy you,thats how I was raised,if you went out on your porch and after listening real good and you than heard a cars motor way in the distance,just wait about 5 min and you'd see it coming up your road.No trouble with neighbors,you looked forward to seeing them[and even hearing them]
  2. #32
    Elite Member DieselPower's Avatar
    Join Date
    Sep 2006
    Posts
    2,761
    Fairfield, PA
    JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
    Quote Originally Posted by Dargo View Post
    An effective bullet trap can be made for far less. It only cost me 2 or 3 hundred bucks to make a 36"X36" one. The most expensive part was the 36"X48"X1/2" piece of armor plating which is welded in the box at a 45 degree angle to deflect all of the bullets down into the sandbox at the bottom. I need to get it back from the gun club I loaned it to a few years ago now that I think about it.
    It's probably taken hundreds of thousands of rounds by now without a single issue. Guys are more than happy to bring in fresh sand to replace the lead filled sand so they can have the lead out of the old sand. I made a 6" deep sand tray at the bottom that slides out for changing. It takes about 100 pounds of sand to refill but it's common for guys to get 10 to 20 pounds of lead from the 'used sand', which is generally recycled.
    I have no doubt a very effective bullet trap can be made for far less. I needed one like I built because I shoot a lot of surplus AP ammo. Even armor plating turns to swiss cheese after a couple of hundred rounds or in the case of a 50 BMG a couple dozen.
  3. #33
    Join Date
    Sep 2006
    Posts
    2,761
    Fairfield, PA
    Quote Originally Posted by zzvyb6 View Post
    A few words of caution about "dirt piles": My 50 BMG easily makes it thru a dirt pile after 5 rounds because of the tunneling effect that occurs when target shooting. That's a depth (thickness) of 10 yards of settled stone free earth. You could look thru the tunnel when penetration was complete. I hollowed out a target area on the side of a hill with my loader for my own personal range out back. The hillside also cuts down on sound levels. Not saying that you need to prepare for this size round, but in case i ever comes up, you need to know the consequences.
    Nice to see I'm not the only guy here that isn't afraid of a real gun. The 50 was my favorite to shoot until about a year ago when I got a 338 Lapua. Man, that baby is even better than the 50 out past 1,000 yards.
  4. #34
    Elite Member
    Join Date
    Apr 2005
    Posts
    4,028
    nicholson, pa
    John Deer 318
    What kind of 50 do you have?
  5. #35
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Wow.. all this talk of 50 cal rifles makes me feel left out.. all I have are 50 cal hand cannons..
    soundguy
  6. #36
    Super Member Dargo's Avatar
    Join Date
    Mar 2004
    Posts
    5,980
    S. IN
    Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
    Quote Originally Posted by DieselPower View Post
    Funny, I have 3 rifles that shoot .50 BMG ammo. Hundreds of rounds of surplus ammo has caused exactly zero damage. I guess you've never had any of the level of armor plating I have. If it were getting hit with armor piercing rounds via a right angle at the same spot you'd get through. At a 45 degree angle, knocking the bullets down into the sand, the .50 BMG would likely take tens of thousands of rounds to hurt it. I know for a fact that hundreds of rounds have just scratched it. Here is a Barrett M107 the day I brought it home.
    Attached Thumbnails Attached Thumbnails Building a gun range, suggestions?-169-jpg   Building a gun range, suggestions?-bar3-jpg   Building a gun range, suggestions?-bar4-jpg
    1982 18" Murray push mower (B&S industrial 8 hp engine!) custom deck, new blade - became unbalanced when one side old blade broke off!
    HF moving dolly - high torque! Dogbone multi-wrench too..wait, it split on first use.
    My trash man is the greatest. No matter how bad the economy gets and how bad stocks drop or how bad home values drop, his business is always picking up.
  7. #37
    Join Date
    Jan 2007
    Posts
    1,182
    Dargo, you are my Idol! I've wanted that piece of hardware since I can remember! However,
    DieselPower,
    You are my HERO! I gave up on the .50 cal some time back, but fell in love with the Barrett 98Bravo, which in my opinion, is the sexiest (yeah, sexiest) firearm I have ever laid eyes on!!!!!!!!!!!!!!!
    http://www.98bravo.com/
    Of course, since I'm not allowed by CINC-Checkbook to make that kind of a $ purchase, I'll probably "settle" for the Armalite AR30 instead.
    I'm looking right now, unbeknownst to my wife or course.
    Podunk
  8. #38
    Gold Member deputyrpa's Avatar
    Join Date
    May 2008
    Posts
    362
    Fort Ann, NY
    2006 Massey Ferguson 3635 Cab
    I was recently looking into a 338 Ultra as a cheaper alternative, but if I had the money, I'd go for the Lapua. I'm planning on testing one out in Colorado elk next season.
    2006 Massey Ferguson 3635 Cab w/DL260 loader, Ford 917 Flail, 6'KK box blade, Leinbach auger
    NH 479 haybine and NH Super Hayliner 68 baler
    1975 Mitsubishi MS-070B excavator with dozer blade
    1984 IH S1824 4x4 5-ton dump truck w/9' plow
    1980 Bolens HT20D, hydro, 20hp Wisconsin (Ducati) diesel, 54" shaft drive deck
    1968 Ford 120 Hydro, 12HP Kohler K301, two 42" magnesium decks & cigarette lighter
  9. #39
    Join Date
    May 2008
    Posts
    362
    Fort Ann, NY
    Quote Originally Posted by greenmule View Post
    Ditto. That's how I grew up too. You had to see who it was driving up the road, and then discuss where they were going, or had been!
    We had "old farmer Jones" who drove to town on his Farmall M. He was a gracious man living a lonely widower's life, who always took time to reveal life lessons to a spastic kid, as only a man of the earth could. I went to college, entered the hustle and bustle of megatropolis, and never took the opportunity to see him during his final years. I regretted my selfishness, and that money-chasing lifestyle. I am in my element again. I could only hope to become "old wannabefarmer Marc", with an opportunity to dispense if only a piece of his wisdom. He'd say that was "a might" better than thanking him.
    Oh yeah....one of his best lines was when I was down at the bridge with my new fly rod. He was putting up through on the M. He stopped, leaned over and shouted, "Fly fishin' is for folks who already have somethin' to eat!" Gave a big grin and continued on his way.... It took a while for that one to sink in!!!
  10. #40
    Join Date
    Sep 2006
    Posts
    2,761
    Fairfield, PA
    What kind of surplus ammo? I suspect it was either regular ball or only conventional AP ammo. Try throwing a couple of Raufoss Mk 211 mod 0 rounds at a 45 deg. armor plate. I think you will find quite a hole. You might be surprised how much armor plating you can penetrate with a couple explosive tungsten core round. My first attempt at making a trap to contain these rounds failed. I ended up having a friend at Aberdeen PG give me a hand designing it. He designed the entry plate to help deflect the explosive force into the water portion of the trap. It still takes a beating but is nothing like it was. I figure the entry plate will need replacing by the end of this year.
    Podunkadunk - Beauty is in the eye of the beholder. The Barrett 98Bravo is a beautiful gun. I was thinking of getting one of them next but opted instead for a 338 Lapua Mag Windrunner M98 made by EDM. I already own the 50 BMG Windrunner M96 by EDM. I guess I figured my 96 needed a friend.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
