I live in rural Mississippi. I own all the land around my house, a 50 acre spread. I need to get the washer off my septic system. I cut the washer drain pipe out of the system and ran the pipe about 50' away from the house. There's a good grade the pipe is running down. I am going to have a good sized hole dug for a french drain. That's where I need some ideas. The land around here is sandy red clay. How big should I dig the hole? Can I use road gravel for the drain? How much dirt should I put back over the gravel? I suppose I can use tar paper to cover the gravel, after I am done. Any advice would be helpful.
