Hiya,
It may
cut down on the shooters perceived muzzle report however, as long as it does not lower the report on a DB meter from the same distance as an unmodified firearm, it should be OK. However, one DB difference and your in NFA land.
Perceived sound is an odd thing, I used to shoot highpower at a National Guard range that had a drop off right in front of the firing line, shooting prone with a M1 or M14 with earmuffs on all you could hear when you shot was the operating rod and bolt cycle however, if you stood behind the shooter you would hear the full report.
I would check with the maker to see if they if they have an BATF&E approval statement on file. Or just go out and get a can, they are a great conversation piece at parties.
