roamerr
I had a 36 x 40 Garage built and installed a Utilitech brand from Lowes 70 watt HPS (High Pressure Sodium) Light for nighttime lighting. The light has a "dusk to dawn sensor" that cuts it on each night. Light works good except that it cuts off and back on every few hours -- maybe 30 minutes and then again in maybe another hour -- no frequency that is constant. It only takes maybe 20 to 40 seconds to relight to full brightness when it does go out. Is this normal? The light is 28 ft up and I really prefer not to change it unless it is really bad. I purchased this light for the long life and because it was "white bodied" and matched my garage.
Here's the light:
Utilitech at Lowe's: 70-Watt High Pressure Sodium Fixture
Here's the light:
