NuBota
Gold Member
NSBound - you're welcome! The folks on this forum are much more skilled and talented then me, so I'm glad you started a topic to which I could add some input....
Here are the instructions for the door kit from ShelterLogic - I just copied the design. But my design didn't require making the slits in the cover (that just really bugged me), was much cheaper, and I think sturdier (no plastic parts)
If you do move it over bare ground, consider the impact of moisture buildup inside - like a greenhouse almost - which can really damage whatever metal is stored inside. I just covered the ground with a heavy tarp tucked under the vertical posts and cinder blocks in the corners. You need to be careful when steering on it, but for the most part it holds up well. I was considering the vent kit (attached as well) but haven't needed it
I like your idea of the earthen cut-out -it would help buffer the wind -but also consider surface drainage. I did something similar because my property is all hills - my "garage" sits at the base of a steep hill - had to add fill to make the pad level. But water flows down the hill in the rain and would have probably pooled inside the shed - so I dug a drainage ditch (and filled with gravel) between the base of the hill and the shed to divert the water.
