HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Other Forums > Rural Living
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-29-2009, 08:31 AM   #1 (permalink)
lhfarm's Avatar
Default Material for garage ceiling
Purchased a furnance for my unfinished garage. Before I install it, I want to close the ceiling. The contractor doing some remodeling work on the house right now says he will enclose the ceiling with either 1/2" OSB or white metal panels. The panels will be $700 more, but he likes them because there is no painting and do a good job reflecting light.
Anyone use white ribbed panels? Good or bad experiences?
Thanks,
__________________
Barry
Lawson Hill Farm
NH TC40DA
'64 IH Cub Lo-Boy
'47 Willys Jeep CJ2a w/ PTO
'49 Willys Jeep CJ3a w/ PTO & 3pt lift
http://www.farmjeep.com/
lhfarm is offline   Reply With Quote
Old 10-29-2009, 08:40 AM   #2 (permalink)
Duffster's Avatar
Default Re: Material for garage ceiling
We use white steel for ceilings all the time and prefer it over OSB.
__________________
"If everyone is thinking alike, someone isn't thinking." George Patton
Duffster is online now   Reply With Quote
Old 10-29-2009, 08:45 AM   #3 (permalink)
Super Member
EddieWalker's Avatar
I thought about using metal panels for my ceiling. My trusses are 4ft apart, so it would be the easist thing to use that would have the strength to span that distance and hold insulation. 7/16 OSB would need some purlins or furing strips to hold the OSB, which would be more work. I also thought about sheets of foam and even having a guy spray it. In the end, I've decided to use 10 in fiberglass insulation that's 23 inches wide. Two of them, side by side will fit between my rafters, and then I will use 1x3 every two feet to hold the insulation bats in place. That's my current plan, and what I was going to do this weekend, but something just came up, so it's put off another week or two.
Good luck,
Eddie
__________________
Link to my Pasture Project http://www.tractorbynet.com/forums/s...81#post1650281
Link to my Deer Blind Project http://www.tractorbynet.com/forums/r...-top-deer.html
Link to video clips of me running my dozer. http://www.tractorbynet.com/forums/r...er-action.html
Link to my thread creating Lake Marabou. http://www.tractorbynet.com/forums/p...ting-lake.html
EddieWalker is offline   Reply With Quote
Old 11-02-2009, 07:44 AM   #4 (permalink)
Gold Member
I have white barn metal on the ceiling in my shop and foil board in the lower bays. The shop ceiling has been in for over 20 years. I would do it again. The lower bays have 15' ceilings so the foil works good there. I wash cars in the shop and handle steel that hits the ceiling some times. A few small scratches but I am totally pleased with it.
Kays Supply is offline   Reply With Quote
Old 11-02-2009, 08:34 AM   #5 (permalink)
lhfarm's Avatar
Quote:
Thanks for your note. I need to make my decision today and was still debating the extra expense. I was concern about how it would hold up long term. Based on your experience and other comments here I think I'll commit to the extra bucks.
__________________
Barry
Lawson Hill Farm
NH TC40DA
'64 IH Cub Lo-Boy
Old 11-02-2009, 05:56 PM   #6 (permalink)
I've had white metal ceilings in my woodworking shop building for 10 years now. Works really well and very easy to put up (provided you have at least a couple of people to help hold it in place while screwing it in place). I had insulation blown in on top of it and I have been very pleased - the insulation works great for heating/cooling, and dampens sound reflection off of the metal as well.
woodchuckc is offline   Reply With Quote
Old 11-02-2009, 06:46 PM   #7 (permalink)
Gold Member
/pine's Avatar
I may not have the right picture in mind...but if it was mine and only a garage/shop I'd use OSB or plywood and install it on top of the ceiling joists or bottom cords (if they're trusses) so it could be used easier for storage...possibly with a set of pull down stairs...
__________________
Slash Pine
/pine is offline   Reply With Quote
Old 11-02-2009, 06:57 PM   #8 (permalink)
Willl's Avatar
I like the ceiling job Carpenter383 did in this thread.
http://www.tractorbynet.com/forums/p...e-ceiling.html
__________________
I refuse to participate in any type of recession.
Timothy 2:11-12
My Photobucket
Willl is offline   Reply With Quote
Old 11-02-2009, 10:00 PM   #9 (permalink)
carpenter383's Avatar
Thanks for the compliment Willl
Pole barn metal works out really nice for a shop ceiling. Mine was around 60 bucks per square for #2 metal if I remember correctly. (a square is 10x10 or 100 sq. ft.)
__________________
DK40SE, loaded R4's, KL401 loader with toothbar = a good chunk outta the bank each month
Problems cannot be solved at the same level of awareness that created them.
carpenter383 is offline   Reply With Quote
Old 11-03-2009, 11:17 PM   #10 (permalink)
Ribbed steel siding on the inside of a pole barn is very much a good choice. Especially if your going to be welding in there. The builder I used to deliver for did a lot of commercial applications replete with all the standard available trim stock for a totally finished job.
I have also seen walls done with osb laid on the side to back up the first four feet of a wall where damage is likely to occour. Tin on the walls will require some sort of interior purlins.
QRTRHRS is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.23061 seconds with 8 queries
