Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Elite Member Mousefield's Avatar
    Join Date
    Aug 2008
    Posts
    2,638
    Qualicum Beach on Vancouver Island, BC. Canada
    Sold 2008 CK35 HST
    Default Greenhouse, partly recycled material
    Had one of my e-mail buddies ask about a greenhouse so thought I would post some pics of one I built about 5 years ago.
    The size was mostly determined by the 3 large (9 ft) used patio doors I got at a reasonable price, $30.00 each. Then wanted to make sure my wife, the gardener, had enough room to move around in it. Have a cement mixer so the perimeter is cement foundation with anchor bolts. The wood is band sawn cedar from our property. The other windows got scrounged for free. The green fiberglass roofing came off a mobile porch. The over all size is 10 X 14 ft. It has power to it, 1 plug and then to a light switch for 4 100 watt bulbs, she does go out after dark to putter around, the lights work very well , nice and bright.
    The middle of the greenhouse is open for her to walk around, open board shelving for flats of starter plants and beds below them. So when you enter the greenhouse the only place that does not have the beds or shelving around the outside is at the door. In the spring I put a pump in our creek and have a hose into the greenhouse for her watering needs. We also have a garbage can, full of water from the roof, that she can use if needed. The garbage can is topped off from time to time with creek water as it warms up nicely and is great for watering. The upper smaller windows I put in so that if it got to hot in there we could open them for ventilation. It's not as good looking as the first one I built at our first house but then that was a kit from the lumber yard.
    Attached Thumbnails Attached Thumbnails Greenhouse, partly recycled material-greenhouserosd-014-jpg   Greenhouse, partly recycled material-greenhouserosd-018-jpg   Greenhouse, partly recycled material-greenhouserosd-015-jpg   Greenhouse, partly recycled material-greenhouserosd-016-jpg   Greenhouse, partly recycled material-greenhouserosd-013-jpg
  2. #2
    Veteran Member jeffinsgf's Avatar
    Join Date
    Mar 2005
    Posts
    1,258
    Springfield, MO
    JD 4410
    Default Re: Greenhouse, partly recycled material
    Man, that is lovely. I love the recycled nature of it, even if it isn't as cosmetically perfect as a kit unit.
    4410 ePR, 3rd SCV, Skid Plates, TuffTop Canopy
    430 FEL, 48 BH, MX-5, Bush Hog Chipper, and more.
    455, 60" deck, MC-519, 3pt hitch
  3. #3
    Elite Member WayneB's Avatar
    Join Date
    Oct 2006
    Posts
    2,829
    New Hampshire
    Kubota B-7500
    Really nice looking and I am sure she will enjoy her new hideout. Keep us updated on the use as well at the internal temperatures.
    Wayne
  4. #4
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Very nice, Mouse! Should do the job.
    Dave.
  5. #5
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    That reminds me of the greenhouse my uncle built when I was a kid. He didn't have sliding patio doors, but he did use a lot of old casement windows and half-glass doors. Nice job! That will probably hold up a lot better than some of those fancy ones.
    Jim
  6. #6
    Veteran Member lakngulf's Avatar
    Join Date
    Oct 2009
    Posts
    1,072
    Lake Martin Alabama
    Kioti CK30
    Thanks for posting Mouse' If I build one it will probably be a lean-to, so your design will work just fine. My next steps (1) move an 8x10 thrifty building (2) decide if two more big trees should come down (3) look for some materials that I can recycle, and still past the inspection by my wife--since it will be near her herb garden. Yours looks great !!
    Regarding #1 above, anyone know how much an your standard 8x10 generic storage building weighs, and if my FEL on a Kioti CK30 would lift it?
    Kioti CK30, KL130 FEL with Markham Toothbar, Land Pride 6' Mower, Atlas 6' BB,KK Tiller, KK Bushhog, Chisel Plow, Howse 66" Disc, 7' Spike Tooth, Hollow 300 Seeder
  7. #7
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Quote Originally Posted by lakngulf View Post
    You didn't say "generic steel" or "generic wood," so I'll take the heaviest (wood). Even with a floor kit, it will probably weigh a bit less than 1000 lb. Consider that a 16' utility trailer with a lot of steel and two axles only weighs about 1500 lb and your building will look like a lightweight by comparison.
    Jim
  8. #8
    Elite Member jimmyj's Avatar
    Join Date
    Aug 2007
    Posts
    4,165
    Ontario Canada
    Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
    Looks great! I am envious that you have such a nice climate. We love to garden too. Thanks for sharing.
    God Bless our brave men, bring them home, safe again.
  9. #9
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,304
    Looks way better than most greenhouses I have seen. Great idea to reuse patio windows in this application.
  10. #10
    Join Date
    Oct 2006
    Posts
    2,829
    New Hampshire
    Kubota B-7500
    We moved one last year using three 6" x 10' pvc pipes and simply rolled it where we wanted it to go. Lot easier to roll than pick it up and less stress on the building. We used the tractor to pull it along and a couple guys moving the pipes around as it moved along.
Similar Threads
  1. New driveway - what material and edging?
    By bczoom in forum Related Topics
    Last Post: 04-25-2005, 08:50 PM
  2. Backhoe stressess and material?
    By andyfletcher in forum Build-It Yourself
    Last Post: 03-11-2005, 10:42 PM
  3. Light Material vs Rock and Dirt Bucket
    By dturnmire in forum Power Trac
    Last Post: 07-01-2004, 09:43 PM
  4. Type of material to use in a horse ring?
    By smilingreen in forum Related Topics
    Last Post: 06-01-2004, 09:09 AM
  5. Fill Material "Cake" ?
    By buzst in forum Projects
    Last Post: 09-11-2003, 09:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
