Get ready to trap yellowjackets!
   / Get ready to trap yellowjackets! #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
As soon as the temps start hitting the mid 70's, the queens will be out looking for a home. They will be active for about a month and then workers will start to appear. In northwest Oregon, late May and June are the usual times to catch them, depending on weather. By July 1 it is too late.
Queens are the only yellowjackets that survive the winter. They can be seen for about a month, then all you see are workers. By that time the queens are in the nest where they will live until winter and they will die off with this year's workers. New queens will replace them next year.
If you are catching workers you are too late--the queen will be in the nest pumping out replacements as fast as you can trap them.
Queens look like very large workers.
The best traps are the ones that use pheromones. Yellowjackets change their diet over the course of the summer starting as vegetarians and changing to meat eaters--that's when you see them cleaning up the front of your pickup truck.
You can use fruit juice and meat as bait but they have to be used at the right time and I have no idea which works on the queens. The pheromones work best--by far.
You can buy traps thru Amazon or at a hardware store. I tried about 3 or 4 kinds of traps until I started using those called "Rescue". They really worked, so that's all I have bought for the last 15 years. Other brands may be just as good now, but you take your chances. Hardware stores often don't stock the traps until midsummer when people get hammered by the workers, and as I said at that point it's too late.
Important: If the queens are active and you aren't catching any, move the trap. Don't wait more than a couple days as you only have a short effective trapping season. I usually have 3 or 4 traps out and catch 90% of them in one spot--and that's about 50 queens. Probably related to what is going on at my neighbor's property. But think about those 50 queens: Probably 50,000 workers.
The Rescue traps are not 100% effective. If you watch, some queens will get in and then later escape, but most don't. If the trap is in a sunny location, they will have less time to escape before they get overcome by the heat.
You can make your own traps, but if you do, I strongly suggest you use the pheromone, which you can buy to replenish the Rescue traps.
Trapping yellowjacket queens can make a huge impact on your yellowjacket problems. Until I found the Rescue traps we had lots of the critters around here. We still have a few, but they are only a minor nuisance now.
Lastly, these traps only catch yellowjackets--they won't catch hornets or other stinging insects. New Info: Rescue now has a trap they call a W-H-Y trap which they say will catch hornets as well as yellowjackets and paper wasps. I have not tried one of these so I can't vouch for their effectiveness. Might try one this year.
No, I have no relationship with Rescue. I simply recommend them because they have worked for me.
   / Get ready to trap yellowjackets! #2
Pilot, I've never went quite that high-tech. Here an almost empty Pepsi bottle w/ lid on and approx. 10 to 15 pencil-diameter holes punched in it works decent for trapping. Do I get any queens ? I don't know if I could tell the difference if I knew it LOL.
   / Get ready to trap yellowjackets! #3
While brush hogging in the pasture last summer I got stung 2 times at two different locations the same day. Those little devils pack a wallop! I never knew there was such a thing as a yellowjacket trap so thanks for posting. Will definitely look into purchase. How do you figure out where to place the traps? It isn't easy to find the nests so is the idea to just place the traps outside and the queens will smell/find them?
   / Get ready to trap yellowjackets! #4
I've got bees building a nest behind the side mirror on my truck, 2nd yr in a row.
   / Get ready to trap yellowjackets! #5
You are lucky! When I get hit bushogging, it's with 10-12 at a time. One day twice in different locations. I've given up mowing that hillside in late summer!!!
Actually, I did get it cleared a week ago. I'll try to get it again in June.
Ken
Unfortunately, I can't tell you where to place the traps--that's just trial and error. That's why you don't want to hang the trap & forget it. If it's not catching anything in a day or two, move it. For me, the location that works well one year seems to work well every year. But that could be related to the presence of a Christmas tree farm off the corner of my property--I don't know. What I do know is that a trap in that corner always does the best. I have 10 acres and none of the other possible locations come close to this on in terms of success.
The manufacturer says the pheromone ("attractant") lasts 2 weeks. Lasts longer for me, but I still recharge after 2 weeks when the queens are out, just to be sure. After that I ignore them and they trap a few workers for a month or so after the queens are gone.
   / Get ready to trap yellowjackets! #7
I use the Rescue traps also at the cabin. I find it's the most effective to place them aroud the perimeter of camp, around 50 feet apart. Any direction they come from, there's a trap close enough to attract them before they get into camp. The most effective location is the tree above our garbage can.
I'm probably not getting queens, as most of the summer I have the traps out, but it's not uncommon to have to empty/ rebait the traps after a couple of weeks because they get so full. At least it keeps them out of your hair.
   / Get ready to trap yellowjackets! #8
Today I ordered "Rescue YJTR-SF4 Reuseable Yellowjacket Trap with Attractant" for $13.33 and "Fatal Funnel - 6 Wasp & Hornet Traps" for $7.93 from Amazon.com. Will give them a try and see what happens. Took a look at the W-H-Y trap but it had several poor reviews so didn't order that one.
   / Get ready to trap yellowjackets! #9
I use both kinds of Rescue traps and they make a big difference.
Ken
   / Get ready to trap yellowjackets! #10
I ordered two Rescue Reuseables today too. I get a few nests each year in this one area by the house. I'll post how well it all went sometime in August. I saw two queens buzzing about today, one just would not leave me alone :mad:
Pete
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
KUBOTA M7-132 (A53084)
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
