njrqs
I hope you guys call a grease trap a grease trap or otherwise you won't have the faintest idea what I am taking about.
Basically all our grey water from everything except the kitchen sink goes into a collection box and out pipes into the yard. No worries.
Kitchen sink water only used to go into another box and then down a pipe to trees but of course it was all clogged up with fat etc. when we got here and the box was overflowing right near the house. Very smelly !!
So I installed a plastic grease trap. No worries. But I have a very flat yard near the house and the outlet pipe doesn't fall sufficiently and the grease trap still overflows.
I have a 40mm (1 1/2") pipe into the grease trap.
Out of the grease trap I have 32mm (1 1/4") poly pipe, partyly underground, partyly above ground to let me direct it into various parts of the yard.
(When I say yard I mean the areas we don't play in)
The water coming out of the grease trap is still very fatty but no solids or anything so it appears to be doing its job OK.
Any ideas?
Maybe I need a proper 100mm (4") line out of the grease trap trenched to correct falls and then turn it into some outfall device but that would go along way from the house.
I could also put in a gravel pit and let all the water go into that.
What I want to do is get the stinky water away from the house but not go digging/trenching big runs of pipe.
Anyone in similar situation??
Cheers
PS - Attached pic shows grease trap at bottom of vertical pipe coming down wall (Pipe along ground is from the pool, not grease trap. I have since raised the grease trap up to give me more head pressure but still not good)
Any ideas?
Cheers
