nmu98
- Joined
- Jun 1, 2007
- Messages
- 1,132
- Tractor
- JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
I came home tonight and by chance happened to walk by the sump crock. I could hear a buzz of a motor and I looked down to see a full crock. The pump was trying to turn, but was not working. The cord was pretty hot.
I unplugged it and started to take things apart. I has a hard time unscrewing the connection so the pump got moved around quite a bit. Once I got it out, I plugged it in and it worked. This is a trash pump so I would not thing a small stone would stop it. While I was taking it apart, the top of the water was covered in a thin film of oil that looked like mineral oil. It even smelled like it.
I put everything back together and it is currently working just fine.
Do sump pumps have a clear oil in them? Might this got too hot and leaked it lubricant? Is this pump junk? I have a full finished basement and I cannot risk water damage. I think the pump is an 3871 - EP04/EP05 Effluent Pumps gould pump.
Any help or insight is appreciated! This is an expensive pump, so replacing it just cause sucks... It should last longer than 7 years.....
