Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Join Date
    Feb 2006
    Posts
    1,237
    U. P. of Michigan
    New Holland T1510
    Default My Menard's entry door freezes to jamb!!!
    So, I had replaced my back door with a new steel entry door with a window which opens and a screen.
    It was from Menards. (<---ya, I know...this may be my big mistake)
    About the same time I had a new furnace put in and added a new heat duct to the basement. The door in question is right at the top of the basement steps and the heat flows up the steps and keeps the entryway warmer.
    The door now freezes to the jamb. Almost like it condenses on the outside and freezes to the weather stripping.
    Sometimes I have to physically kick the door to break it free in order to open it and get out.
    It may be due to the new heat duct in the basement causing that area to have more heat and causing the condensation. I would think an exterior door made for this purpose should not do that.
    I cannot figure out what to do. One of these days I may never get it open.
    Any ideas?
    Is there something I could apply to the door or weather stripping to stop it from freezing?
    I probably need to replace it totally, but this time of year is not the time to do it.
    Also, there is no way to put a door at the top of the basement steps conveniently either. There are many things in the way and no room for a door.
    Thanks in advance.
  2. #2
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    17,949
    Central Ohio
    Kubota MX5100
    Default Re: My Menard's entry door freezes to jamb!!!
    What does the fact that it was bought at menards have to do with anything?? Doors there are built in the same way as any of the ones from lowes, HD, etc.
    Is the problem that it is actually freezing as in gettig cold and moisture icing together, or is it just humidity changes swelling and contracting things????
    Who installed it and how was it installed??
    The proper way to install a door is to leave the frame opening about 1" wider than the door. Then use a shim kit where the screws go so you dont bow the jambs. This gives the door room to expand/contract.
    If you made the rough opening the exact same size as the door hoping NOT to use shims, that can cause all sorts of problems as humidity changes.
    I have two menards $99 special "commander" series steel doors on my shop. The shop is only heated 3 or 4 days a week on my off days. Un heated on my work days. I have never had a problem with either of the doors in 2 years.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #3
    Join Date
    Feb 2006
    Posts
    1,237
    U. P. of Michigan
    New Holland T1510
    It literally freezes / ices up to the weather stripping.
    When I kick it loose, I can actually feel ice all around the outside edge where it meets the weather strip
    Once broke free, it opens and closes correctly.
    No swelling, no warping.
    And, it does not do it every day / night.
    It was professionally installed. It is a pre-hung door also.
    Some people around here say Menards has ...ahem....less than quality stuff, so you have to be careful of their good deals
  4. #4
    Platinum Member Craig Clayton's Avatar
    Join Date
    May 2009
    Posts
    863
    Uxbridge Ontario Canada
    L2250 Kubota
    I have insulated steel doors on my high level of insulated house. I believe MI is somwhere cold. The door is freezing because the temperature on the exterior side is low enough to freeze. As new doors are made to closer tolerances the gap around the door is much less. I presume the old door was wood slab and had a loose fit which allowed lots of house to keep it frost free.
    Did the door go in the existing frame or did it have a new frame.
    As suggested above the door frame may have some very tight spots that need reshimming. If you do not have a exterior storm door you might have to tarp over the door to check it out. I would you find something to figure out how much gap the door has, maybe very dry out plastercine in little spots and see how much they squeeze. The probablty is the latch side will be bowed in, because the hinge side is kept straight by the doors hinges.
    I installed wood core exterior storm doors this past summer and I get frost on them. My Sears aluminum doors with the high winds had been wrapped around too many times and were in rough shape.
    Craig Clayton
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,732
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Not a Menard's related problem. Too much moisture in the house.
    I'd suggest considering/adding a storm door. That solved my similar problem, and it was easy to do. I bought the steel door from a local lumber yard but bought the storm door from Menard's
  6. #6
    Elite Member ToadHill's Avatar
    Join Date
    Oct 2005
    Posts
    2,711
    Catt county New York
    Kioti DK35, Ford 8N, Oliver Cletrac
    Keep the weather strip sprayed with WD40. It will repell the moisture and keep the door from sticking yet keep the cold draft out.
    I can't control my day but I can control my attitude.
  7. #7
    Gold Member Jimmy Joe's Avatar
    Join Date
    Aug 2008
    Posts
    373
    Medford Wisconsin
    I agree with adding a storm door if you don't already have one.
  8. #8
    Join Date
    Mar 2010
    Posts
    2,096
    Spray silicone lube around door frame and bottom weather strip. Old door allowed enough heat out that freezing was not a issue. Storm door may solve problem.
  9. #9
    Join Date
    Apr 2008
    Posts
    17,949
    Central Ohio
    Kubota MX5100
    I agree with what everyone has said thus far. Newer doors seal and insulate better. This keeps the heat in the house better and as a result, your door is freezing.
    Try the lube where you are seeing the ice and see if that doesnt solve your problems.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  10. #10
    Elite Member zzvyb6's Avatar
    Join Date
    Dec 2006
    Posts
    3,546
    michigan
    jd 1070
    My door from Menards is working very well thank you. Mine came with its own casing. When I tore outh the old casing, I found out there was NO insulation behind the casement boards. I filled the gap with non-expanding foam. Now I have a warm entry way even the dogs like.
    My old door used to have ice on it, probably because the humidity condensed on the door as it leaked out, then froze. So, I would recommend dialing back the humidity and adding some extra air barrier (like a storm door).
    There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
Similar Threads
  1. Construction question (entry door)
    By Richard in forum Rural Living
    Last Post: 09-26-2010, 09:30 AM
  2. Installing a pre-hung entry door
    By 5030tinkerer in forum Rural Living
    Last Post: 11-14-2006, 11:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
