Results 1 to 10 of 22
01-11-2011, 04:33 PM #1Bronze Member
- Join Date
- Jan 2011
- Posts
- 71
- Location
- Ft Worth TX / Datil NM
Property Pin and Fences
I want to install a metal pipe fence around my 40 acres. The pipe will only be used for the corners and T-post and barbed wire in between.
So how do I dig a hole and set my pipe if there is a survey pin in the corner? I know the pin must be left alone. I am guessing I will have to set the pipe on my side of the pin. None of my current neighbors have any fence up.
01-11-2011, 04:45 PM #2Elite Member
- Join Date
- Apr 2004
- Posts
- 4,763
- Location
- Bay Area-Ca and Olympia WA
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23, Craftsman Mower
Re: Property Pin and Fences
Don't know if it is correct... my Grandfather ran his fences down the line stopping 3' short of the corners to make a 45 and avoid the pin... also made the corners stronger.
His neighbors ran there fences 5 feet back for access and someone would always mistake the fences as the property line..
My Grandfather didn't want that to happen.
01-11-2011, 05:46 PM #3Veteran Member
- Join Date
- Aug 2005
- Posts
- 1,754
- Location
- Downeast Maine
- Tractor
- Kubota L275DT; Ford 8N
How big is your pie?
I wouldn't dig a hole as you will disturb the soil and the pipe would be more apt to lean.
open the hole as much as you a with a 5 foot pry bar.finish setting the post with a sledghammer.
I don't remember the term, but you can get or make a short piece of pipe to slide over the top of than your post, with a plate of 1/2 inch steel welded on top . This will keep the post from swagging. Maybe put a couple of supports at 45' to the ground in the directions of the fence.
01-11-2011, 06:18 PM #4Super Member
- Join Date
- Aug 2009
- Posts
- 5,277
- Location
- Beaver Creek, Northern Michigan
- Tractor
- Kubota B2320
We have some surveyors here. Dodgeman for one.
Might shoot him a private message and ask for his guidance. Couldn't hurt.BP
"Some chickens, some gardens and a Kubota."
01-11-2011, 06:30 PM #5Veteran Member
- Join Date
- Sep 2000
- Posts
- 2,045
- Location
- russellville, arkansas
- Tractor
- Kubota M4900, B7510 and RTV
put the fence as close to the line as you can...
heehaw
01-12-2011, 12:56 AM #6
40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
Isaac Asimov
01-12-2011, 07:32 AM #7Platinum Member
- Join Date
- Mar 2002
- Posts
- 996
Do you know for certain that the pin is actually the corner of the property? I believe in most cases that it is, but in some cases they may not be. On our property, the fence has been there forever (not really, but longer than anyone alive can remember). The pins that are in the "corners" of our property are not the actual corners of the property. The corner is only a few feet from them, but since the posts were already there, we couldn't set the pins in the corner (so it's kind of the opposite of your problem).
If it were mine, I would either set the corner posts inboard of the pin by a foot or use the "stop short and 45" method that somebody mentioned earlier. That's a pretty good idea.
Good luck and take care.
01-12-2011, 07:38 AM #8
put THE CORNER ON A 45 THAT WILL GIVE YOU A STRONG CORNER AN AS SAID ABOVE.
Army Grunt"Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
01-12-2011, 09:57 AM #9Bronze Member
- Join Date
- Jan 2011
- Posts
- 71
- Location
Yes the Pins are the property line for sure. It was originally a square mile that was divided up in to 24 pieces and mine is 40 acres. One surveyor did the whole place a few years back when it was divided and nothing has changed.
My piece is a triangle with a county road on one side. State property on another side, and my uncle and some other person on the third side.
I am only wanting to fence the road side and the other side between the other guy that is a less than a good neighbor.
The piece where the 3 of our land meets will be easy I can just straddle the pin with the pipe. The other two corners along the road is where I will have to move it a bit. I figure I can plant a 45 corner with the corner on the county road side just inside the pin to my side. And the other two ends of the 45 will land on the line and be on the line from there on out.40 acres in New Mexico
01-12-2011, 10:11 AM #10
Good advice. On our property, due to terrain and other issues, some of our pins are offsets and not the actual property line. The pins are merely reference points. The actual property line is x number of feet/inches away fron the pin. We have a creek that runs between two properties. In that case the pin is inside my property, however the property line is x number of feet away from the pin... down the center of the creek. (Of course the creek over time can change, however the line will not. We just "say" down the center of the creek for ease of discussion.)
Kubota M8540HD12-1 (2010), R4s with 3 Sets of Weights, 2 Remotes (SCD & FD), Rear Work Light and Down Exhaust
Kubota LA1353 FEL with QA 72" Bucket, Self Leveling Valve and 3rd Function Remote
CCM Category II Hydraulic Toplink with Flow Restrictors
Kubota QA 48" Pallet Forks
Kubota M8180 Ballast Box filled with concrete (1,800 lb)
Land Pride QH-20 Quick Hitch
Land Pride RCR2672 6' Rotary Cutter
Land Pride GS2596 8' Grading Scraper
BAC Industries BG-10 Post/Tree Puller
