Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Veteran Member lhfarm's Avatar
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    Default To paint or not to paint garage/workshop walls
    I'm installing OSB over insulation in my garage workshop (sorry about picture - phone cam). I need to decide if I'm going to paint it while I have shelves/benches pulled out. I really don't mind the look of the OSB, but wonder if I could improve the "brightness" by painting the walls white or some other light color. It is a garage/workshop and it does get dirty in here.
    Wondering if others have experience with painting/not painting OSB walls. If so, I'd like to hear opinions.
    Thanks,
    Attached Thumbnails Attached Thumbnails To paint or not to paint garage/workshop walls-garagesink-jpg
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
    '47 Willys Jeep CJ2a w/ PTO
    '49 Willys Jeep CJ3a w/ PTO & 3pt lift
    http://www.farmjeep.com/
  2. #2
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,922
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: To paint or not to paint garage/workshop walls
    I vote YES. Do it now while everything is out of the way or you will never do it. White semi-gloss would be my choice.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  3. #3
    Super Member
    Join Date
    Nov 2003
    Posts
    8,384
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Back in 1990 I insulated the walls of my 24X36 garage with fiberglass, then nailed on 7/16 inch OSB inside. Thought about painting, but now 20 years later shelving, workbenches, storage etc. covers about 65% of the walls, and the remainder has tools and other stuff on racks hanging up. If you plan to do what I did, don't waste your time and money painting.
  4. #4
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    I hate the look of OSB, it will turn yellow/brown over time, so I would paint it for sure.
    JB.
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  5. #5
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    Quote Originally Posted by kennyd View Post
    X's 2.
    Does look in the photo to be on the dark side..
    Dennis
    "Winter 2013 a majority of the country is setting new cold records, Colorado is setting new record HIGH's"
    "If at first you don't succeed, skydiving is not for you."
  6. #6
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    I have OSB in my garage and I like it's natural look. White would make it brighter for sure, but you will see more of the dirt if painted. Not something I want to bother with.
  7. #7
    Veteran Member buck12's Avatar
    Join Date
    May 2006
    Posts
    1,216
    NW Mississippi
    Mahindra 2615
    Default
    X3 to avoid being in the dark
  8. #8
    Veteran Member orezok's Avatar
    Join Date
    Jan 2004
    Posts
    1,644
    Mojave Desert, CA
    Kubota B7800
    Another advantage to painting is that it binds the fibers. Ever reach up to get a tool and get a splinter under your fingernail. Painting prevents that. If you don't want a "color" then just seal it.
  9. #9
    Platinum Member eepete's Avatar
    Join Date
    Oct 2009
    Posts
    962
    Efland, NC
    JD 4520, Kubota B21, JD 318
    X4 - and re-emphisis that if you don't do it now you probably never will.
    yeah, with time it might get a bit dingy but I've seen my garage with and without paint, and it was much brighter with the paint.
    As you can see, I left a 2' boarder on the bottom that I did with pressure treated plywood. Less dirt problems.
    Pete
    Attached Thumbnails Attached Thumbnails To paint or not to paint garage/workshop walls-paint_done-jpg
    '09 JD4520 Cab (60HP), '97 KubotaB21 TLB (21HP), MX6 rotary mower, SB1106 6' Sickle Bar, BB3272 6' box blade, GradeMaster 7' Landplane, 6' landscape rake, Woods GTC 40" tiller, PHD 9" auger, 4' x 8' chain harrow, '90 JD318 (18HP gas) with 48" MM mower, 54" front blade, 47" snowblower.
    Volunteer Firefighter.
  10. #10
    Super Member
    Join Date
    Apr 2006
    Posts
    6,484
    Wise county Texas
    Kioti DK 35 now
    Quote Originally Posted by orezok View Post
    That hurts just thinking about it!!!
    Dennis
Similar Threads
  1. stick built or other ??????
    By Beavis in forum Projects
    Last Post: 03-31-2010, 08:26 PM
  2. New member- old tractor
    By mattgo in forum Massey Ferguson Owning/Operating
    Last Post: 04-09-2008, 03:09 PM
  3. Super C, paint?
    By coffeeman in forum General Vintage Tractors
    Last Post: 04-01-2008, 02:16 PM
  4. painting implements with cans of spray paint
    By Pooh_Bear in forum Attachments
    Last Post: 08-18-2006, 04:34 PM
  5. Touch-up paint
    By Gfsimon in forum Kubota Owning/Operating
    Last Post: 05-09-2001, 09:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
