Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Veteran Member lhfarm's Avatar
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    Default Removing veneer from table top
    We have an old wood dinning table we leave on our front porch. The veneer has start to lift and buckle. My wife wants to remove it and has been told to rent a "steamer". Not sure what that is, but I'm wondering if one of the multi-task vibrating tools might do the job.
    Any suggestions for the right tool or where to rent a steamer if it is the correct method?
    Thanks,
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
    '47 Willys Jeep CJ2a w/ PTO
    '49 Willys Jeep CJ3a w/ PTO & 3pt lift
    http://www.farmjeep.com/
  2. #2
    Veteran Member Lloyd_E's Avatar
    Join Date
    Nov 2003
    Posts
    1,500
    South Shore Nova Scotia Canada
    2008 Kioti DK 45 sc
    Default Re: Removing veneer from table top
    Depending on the glue used, steam might work. You could try placing hot wet towels on the top. There may be enough moisture penetration to start lifting the veneer. Once it starts you could probably peel it off.
    Good luck... post pics sound like an interesting wood working project.
    Lloyd
    Work hard to get it down - play like tomorrow may end!
    Small Horse Farm: 12.5 acres: 2008 Kioti Dk 45SC with Cab, FEL, BH, 6' snow blower, 7' back blade, 7' box blade, 6' bush hog, 9"& 14" auger, 8' chain harrow, 4" chipper, sand spreader, 7' landscape rake, 3pt quick attach & coffee holder.
  3. #3
    Gold Member vic4news's Avatar
    Join Date
    May 2007
    Posts
    286
    Merrimack County, NH
    Kubota B3030
    I would just use a palm or belt sander on the top. Most veneers are so thin that it doesn't take much to sand through them.
    Vic
  4. #4
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,803
    Nova Scotia, Canada
    Make them nice wet towels and apply the iron to them.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  5. #5
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    I should have added pictures . Thanks for the quick replies. Towels and iron sounds doable. Don't have a belt sander, so maybe this is a buying opportunity!
    Attached Thumbnails Attached Thumbnails Removing veneer from table top-tabletop1-jpg   Removing veneer from table top-tabletop2-jpg
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
  6. #6
    Join Date
    Aug 2001
    Posts
    20,803
    Nova Scotia, Canada
    One of the Multi Tools with a scrapper blade should also work.
    Egon
    Livin in a
  7. #7
    Platinum Member DennisArrow's Avatar
    Join Date
    Jul 2003
    Posts
    766
    Sugar Valley, Ga
    Iseki TL 2300, Kubota RTV, Kubota B7610
    Is that your "back porch" table. Is that what is it gonna be used for or is it actually gonna be used in a kitchen/dining room. I hate to see a fine old oak piece like that destroyed. Perhaps is there anyway to get some replacement oak veneer to repair replace the old?..........Is the purpose just to get a table top work surface?...........
    For me........the towels/steam are the best bet to save a surface that is going to be "nice". Sanding and scraping the veneer off is just gonna leave LOTS of gouges and humps that will make the top look like junk. Wait for it to dry for several days before sanding/staining/finishing
    Doesnt matter if it is just a work surface; but if the intent is to pass it down to your daughter or even do some guest dining.....I would take care of it...........GET SOME VENEER AND REPAIR IT........God bless.....Dennis
  8. #8
    Veteran Member johnrex62's Avatar
    Join Date
    Jul 2010
    Posts
    1,013
    Bastrop County, Texas
    Kubota L3700SUHST
    I watched this process recently on an episode of American Restoration. They put damp towels on top and used a steam iron (laundry style) to heat and soften the adhesive and a putty knife to peel off the veneer.
    He said it was just like taking off wallpaper....but a lot harder.
    Kubota L3700SUHST, AG-Meier Mohawk 5' Rotary Cutter, Armstrong AG 5' Boxblade, Armstrong AG 5' Landscape Rake
    Scotts 50560x8 50" Riding Mower
  9. #9
    Join Date
    Jan 2009
    Posts
    1,319
    upstate South Carolina, Greenville
    Kubota M6800, Massey Ferguson 240
    Good advice for steam, definitely don't use sandpaper or a power scraper. You will probably disappointed in what you find underneath. Most veneered pieces used cheaper wood underneath, something not nice enough to stain and finish, hence the need to venner it with something finer. So it depends on your use.
  10. #10
    Join Date
    May 2002
    Posts
    1,344
    Central Indiana
    NH TC40DA
    Quote Originally Posted by DennisArrow View Post
    The table is on our covered front porch and has been there for at least 15 years. We eat out there about every meal during the summer. It has taken a lot of abuse, but is too heavy to move indoors in the winter, although I might be able to move it with my forks - just no room to store.
    We are going to try the towel/steam iron approach and I'll see if we can find some veneer.
    Thanks,
    Barry
    Lawson Hill Farm
    NH TC40DA
    '64 IH Cub Lo-Boy
Similar Threads
  1. Replies: 472
    Last Post: 01-21-2012, 11:34 AM
  2. welding table
    By Chain Bender in forum Welding
    Last Post: 03-26-2011, 06:56 PM
  3. Welding table from a cast iron tablesaw top?
    By jeffreythree in forum Welding
    Last Post: 03-25-2011, 10:49 PM
  4. Welding Table Build
    By weldingisfun in forum Welding
    Last Post: 10-03-2010, 12:45 PM
  5. Rear Finish Mower Is the top link needed for a RFM?
    By GaryS in forum Attachments
    Last Post: 06-02-2007, 12:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
