clemsonfor
Super Member
Clemsonfor:
I am looking at property about an hour South of Augusta Ga on sandy loam and loamy sand, mostly scrub pine and scrub oak 1-6 inch diameter.
what is the best, most cost effective way to cut trails through the property?
if the 1-4 inch stumps rot out on a season or two what is the best way to flush cut them to the soil?
I would use a Big weedeater with the beaver blade (or brush blade). That or a chain saw. If your doing like miles of property you may want to rent a bobcat and push it or get a mulcher head on it. I would say tractor but there is no way your bushhogging a 6" stump with anykind of cutter short of the "Brown Tree cutter". Cutting 1 mile of trails with a brush saw will kill you.
The PINE stumps will rot out, the hardwood will stay live and "stump sprout" into a bunch of little trees to cut down next year. If you plan on bushogging each year this may not be a problem for you. But i personally would cut the stumps and brush on a 100% solution of 41% glyphosate (trade name roundup) right after you cut the hardwood. OR come back after they have resprouted in late summer before leafe color change say late september and spray the re-growth with a solution of glyphosate at the labled rate for hardwood control.
