Results 1 to 4 of 4
  1. #1
    Super Member JDgreen227's Avatar
    Join Date
    Nov 2003
    Posts
    6,711
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Default My wet-dry vacuum didn't tolerate getting wet !
    A few days ago, I spilled a large quantity of clean water (pail handle broke) down the top of a ten year old, Craftsman shop vacuum. It wasn't running at the time, I immediately took it outside and inverted the vacuum, and within the next half hour, took it all apart (except for the motor assembly) blew as much water as possible out of the innards, and let it sit in the sun the entire day to dry out. Well, I reassembled the vac, turned it on, and it ran fine for a few minutes, then began smoking out the top vent where the motor exhausts hot air. I shut it off immediately,
    I took it apart again, and found the motor was so hot it was binding for some reason. There was nothing interfering with the rotation (like a loose screw), the brushes, bearings, and bushings are not damaged or corroded. It was rotating in the proper direction before it began heating up, and the cord supply for power is ample sized (16 gage) and undamaged. The copper wire windings on the armature look scorched, but the only part of the motor that the water could have affected is the paper wrappings of the field windings of the motor, and since they were dry when I reassembled the vacuum, why does it run hot and bind up? Thanks for any input you can provide me.
    Always be willing to admit your shortcomings, there is no shame in not knowing how to do something. The shame is in NOT admitting you don't know how to do it.
    If you have a small truck, limit yourself to small loads, if you want to carry the big stuff, get a big truck.
    Never be ashamed of making a mistake. The only people who never (bleep) up are people who never try to do something new.
  2. #2
    Super Member Iplayfarmer's Avatar
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Massey Ferguson 1215, Toro 266-H, Pennsylvania Panzer, Case 444, Craftsman 14/6
    Default Re: My wet-dry vacuum didn't tolerate getting wet !
    Water and electronics never mix, as I'm sure you well know.
    It's a little late now, but in the future let something like that sit for a few days or more to completely dry out before attempting to operate it. Water can get into little areas (like between windings) that you'll never see and won't be able to blow out.
    From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
  3. #3
    Join Date
    Nov 2003
    Posts
    6,711
    Central Michigan
    Quote Originally Posted by Iplayfarmer View Post
    Was beginning to wonder if I would ever get a reply, thanks. I wouldn't call an electric motor "electronics" but I get your point. The vac is about 20 years old now, still worked great though. I can use the parts (filter, tank, hose, brushes, etc) on the other vacs I have.
    Live and learn !!!
  4. #4
    Join Date
    Jul 2005
    Posts
    5,151
    Idaho
    Quote Originally Posted by JDgreen227 View Post
    Live and learn !!!
    I suppose the vacuum doesn't owe you a dime if you've had it for for 20 years.
    I've had complex electronics completely submerged in water (by accident, of course). I'll pull the battery and let it sit for a week before I try powering up again. So far I've had good luck with this practice. I have an old Palm TX that has been dropped in the canal. It's still going strong after about 5 years. It's totally obsolete now, but it still works.
    Whether complex electronics or a simple circuit, the principle is the same. Electricity and water don't mix. Without electricity running through, it's just a hunk of metal and plastic. It's when you add electricity to the device that the damage happens if it's not all dried out.
Similar Threads
  1. Clutch: Wet vs. Dry
    By Beavis in forum Buying/Pricing/Comparisons
    Last Post: 01-25-2010, 08:40 PM
  2. Lawn Vacuum for Garden Tractor
    By jnelson in forum Build-It Yourself
    Last Post: 04-02-2009, 08:51 PM
  3. Wet Clutch vs. Dry Clutch
    By Buzzard7 in forum Kubota Buying/Pricing
    Last Post: 11-01-2007, 03:44 PM
  4. Wet saw or dry saw?
    By RayCo in forum Projects
    Last Post: 09-07-2007, 04:13 PM
  5. 2000 3206 Vacuum PTO Problem
    By mossydave in forum Cub Cadet Yanmar & CUTs
    Last Post: 07-30-2006, 09:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
