weesa20
Looking at a piece of property that can be had for a steal (2-2500/acre) which is cheap around me (land usually starts at around 10k/acre)...problem is 1) unknown perk status (would be tested before closing and if no perk-no deal) 2) high tension power lines and easment run through proprty and take up about 1/4 of the land. I know folks on the other ends of the property with the same easment hay under the power lines or use it as a pasture, just not sure if it is a good idea or not. any thoughts or experience with this type of situation. If we build the house would be as far away from the lines as possible.
Thanks for any input.
Weesy
Weesy
