Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Join Date
    Jun 2007
    Posts
    104
    Litchfield, Maine
    1970 PUG (sold it...looking for a newer one), 1969 Case 430
    Default Re: How to smooth a lawn?
    Look up a "Harley Rake" [I think]. It's a "one pass bed prep" kind of roto-tiller that tears up the upper 2" or 3", then feathers the top soil to a smooth finish ready to seed then roll. I don't know who makes them but someone in your area must have one.
    The one my neighbor has is 6' wide and runs off his 3-pt-hitch. He is a professional landscaper.
    Check 'er out here... Order Harley Rakes Online!
  2. #12
    Silver Member paulemar's Avatar
    Join Date
    May 2011
    Posts
    117
    Pittsburgh, PA
    Kubota BX25, 60" MMM, 3 point hitch
    Default
    12000 sq ft isn't that much, but it is big enough to be quite a job to fix. I've got a field of around 2 acres that was previously used to train a horse in the Spring when everything was still wet and soft. The horse left foot print impressions, some about 4 " deep, all over the place. I've been trying to think of a way to smooth it out a bit more ever since I tried filling the bigger holes with soil. It's still too bumpy when I mow so I am going to drag my core aerator behind the mower every time I mow the field. (Old JD 210 garden tractor and Brinly core aerator) I figure that pulling up plugs of soil for the rest of spring, summer and fall might pull up enough soil to settle in the remaining shallow depressions as I mow and over the winter. However, it is a field even though it is treated as a lawn and may make a mess that would not be suitable in your situation. If I'm lucky maybe it will work, but I haven't been able to come up with anything else short of a complete makeover which isn't worth the trouble.
    BX25, "60" MMM, 3 point hitch, Brinly 12" cat 0 1 bottom plow, TSC Countyline carry all, Kubota ballast box, 4X4 Loyal drag harrow, BXpanded Piranha tooth bar, Bro-Tek rear skid plate, Bro-Tek wheel spacers, Bro-Tek backhoe ripper tooth. Kubota BX2763A front plow, Phoenix T4 48" rototiller, Harbor Freight Quick Hitch, BXpanded Quick-on Work light Kit.
  3. #13
    Gold Member Garybake's Avatar
    Join Date
    Sep 2011
    Posts
    348
    Macomb & Kalkaska, MI
    Kubota BX24, Cub Cadet LTX1050, JD 120
    Quote Originally Posted by Pilot View Post
    I have a JD 770 tractor with ag tires, a cultivator, a blade, a disk and a chain harrow. I suspect I don't really have the right equipment.
    I suppose I could rip out the lawn and start over, but at 12,000 sq. ft., that would be quite a job and I have a long list for this summer already. Besides, what would I do with the sod I ripped out?
    So, what's a good, easy way to smooth out the lawn?
    I would tackle half of the job as a reseed and use your chain harrow to fill/smooth soil onto the other half to repair after cutting it short. After reseeding half you can decide if next year you have to repeat with the other half. Or a fraction therof, try a third reseed.
Similar Threads
  1. John Deere for large lawn and garden(s).
    By WillysWoodPile in forum John Deere Lawn & Garden
    Last Post: 12-25-2010, 03:52 PM
  2. How about a chain harrow to smooth lawn?
    By sixdogs in forum Attachments
    Last Post: 05-02-2010, 01:53 PM
  3. Equipment to do lawn restorations???
    By Patriot in forum Owning/Operating
    Last Post: 06-18-2007, 09:13 PM
  4. Redoing the lawn
    By Oliver550 in forum Attachments
    Last Post: 04-15-2004, 11:38 PM
  5. Murray Lawn Tractor Recall
    By BB_TX in forum Owning/Operating
    Last Post: 03-24-2004, 03:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
