Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Elite Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    4,493
    Central Maine
    2003 New Holland TC30
    Default Re: slab options for a garage
    There are cheaper ways! Many people slope the land and add gravel. They don't use a slab- just a thick base of gravel. Then they either build a pole building or a stick frame on sauna columns. Depending on the size of the building (small one)- the might just let it sit on cement blocks and build stick frame- check local regs.. There are many mobile homes that sit on top of gravel pads in Maine without any cement. Local gravel haulers can tell you how thick it has to be to work.
    Good luck with what you do. For fast lawn cutting- consider a ztr.
    2003 NH TC30, International Agritech 5' Bushhog, Carryall, Camo brush trailer, Gravel gravity dump trailer, International single plow, International disc harrow, Bucket mount Snowbear snowplow, hiller/bedder, Craftsman ZTL 7000, CCRT4, My favorite 20oz hammer I left on the woodpile a month ago.
  2. #12
    Join Date
    Sep 2009
    Posts
    1,531
    The County, ME
    Kubota M5640SUD
    Thanks for all the feedback Gents.
    I'm familiar with the mono-slab... If I do pole construction, do I build on the slab or do the poles run through the slab to footings below the frost line?
  3. #13
    Veteran Member Depmandog's Avatar
    Join Date
    Nov 2010
    Posts
    1,307
    Buckner MO
    2005 Kubota L5030 GST; Farmall 706
    Default
    Quote Originally Posted by keegs
    Your poles are your foundation. They are placed below the frostline of your area. Several threads on here about the correct way to set your posts. Trust me - lots of back and forth banter about which way is best. Use a concrete round under your posts, attach some hardware towards the base of the pole to anchor into the poured cement. Some say fill cement to the top / others say don't.
    Dean
    "Get busy living, or get busy dying" - Morgan Freeman in "The Shawshank Redemption"
  4. #14
    Member
    Join Date
    Apr 2012
    Posts
    34
    N. Texas
    Several Blue and Red
    Quote Originally Posted by Depmandog View Post
    Large commercial buildings built around here, cheapest kind of construction, use a steel frame attached to a "pole" buried in concrete. The building is built and when finished the floor is poured (floating) and is flush with the top of the hole filled with concrete that the pole rests in. I think this part is a moot point....
    Personal opinion: My shop was built and later a concrete crew came in and poured the floor 5" thick which came up almost to the top of the treated 2x6 that formed the bottom framing around the perimeter of the barn and the board to which the metal siding (lower end) was attached. The bottom board was a ready made form and remained in place after the pouring which covered the top of the concreted pole hole. I did drive 60d nails into the poles to anchor it all together somewhat.
    Has been 7+ years now and even with last year's drought there has been a minimum of building shifting in this heavy clay soil and my doors (2 ea 12x5, 2 ea 10x5, and a 3' passage door) are still in place and work correctly.
    Here is a pic of it after I had it built: 30x50 with 15' shed.
    Attached Thumbnails Attached Thumbnails slab options for a garage-image003.jpg
  5. #15
    Join Date
    Sep 2009
    Posts
    1,531
    The County, ME
    Kubota M5640SUD
    Spent the past week up at the ME farm getting things finalized on the new garage work. I've got two guys lined up.
    There's site work needed to prep for the slab. The excavator is going to scrape the sod, compact the earth and then bring in 50-60 yards of crushed stone to form a pad and an approach with a two foot margin and a minimum of 12" of aggregate. The crushed stone base with be compacted and the area around the garage will be shaped up with a mini dozer to address a slight grade. Work starts next week.
    The builder teaches shop at a local high school and takes jobs like this during the summer months. He built the chimney on the house a few years ago. He's going to pour the slab and put up the building. The slab is 24'x24'x5" with an 18"x12" thickened edge with re-bar in the thickened edge and 6"x6" road mesh in the field. The building is 2x4 frame with 10' OSB sheathed walls, a trussed 6-12 pitch, vinyl siding, metal roofing, 16' steel, insulated roll up door and a a steel man door. Work starts the end of June.
    Total price (excavation/prep, slab and building) is $15k.
    Stopped off at the Kubota dealer while I was up there too...
  6. #16
    Join Date
    Aug 2005
    Posts
    1,757
    Downeast Maine
    Kubota L275DT; Ford 8N
    Quote Originally Posted by keegs View Post
    Sounds like your ducks are in a row. have you considered also putting a layer of styrofoam under the slab? http://building.dow.com/na/en/applic...dationslab.htm Not only will it help keep the floor a little warmer should you ever decide to work on something in winter; but it will also distribute the slab weight better and reduce cracking.
  7. #17
    Veteran Member Carl_NH's Avatar
    Join Date
    Apr 2002
    Posts
    1,814
    Coastal NH
    01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
    This is exactly the slab we did for our 24-36 barn 11 years ago - no problem, but i concur you should lay down plastic sheathing before concrete or better put down 1" styrofoam below the wire for insulation.
    Carl
    Kubota B21TLB, Ferris IS2000, Cub Cadet 1811
Similar Threads
  1. Types of slab foundations
    By TigerfaninAR in forum Projects
    Last Post: 10-20-2010, 10:03 AM
  2. Asphalt for storing hay
    By Robert_in_NY in forum Ag Tractors & Machinery
    Last Post: 04-09-2009, 07:34 PM
  3. Making a Floor Drain in Garage ?
    By wawajake in forum Projects
    Last Post: 12-22-2008, 09:14 PM
  4. Garage Renovation question
    By BrentD in forum Projects
    Last Post: 12-19-2008, 10:20 PM
  5. Garage floor options
    By Will in forum Related Topics
    Last Post: 06-22-2003, 10:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
