Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Join Date
    Sep 2008
    Posts
    532
    North East TX
    Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
    Default Advice wanted on water line to house
    Im running new water line to my future house location. The mgr of the local water coop is a good friend of mine. The line Im tying into is 2". I am currently planning to run 2" all the way to my house (approx. 200 yds off the road). Another friend of mine advised me to use a larger meter than the standard 3/4". The coop mgr said that would be fine, so long as I paid the difference in the larger meter. Any advice from you guys? Is this a good thing, or a waste of money? thanks
  2. #2
    Join Date
    Jan 2011
    Posts
    191
    Central Ohio
    JD 5055, Mahindra 315, JD 2040
    Default
    Where is the meter located? What is the cost difference? How much water do you plan to use?
  3. #3
    Join Date
    Sep 2008
    Posts
    532
    North East TX
    Default Re: Advice wanted on water line to house
    Meter will be located along road frontage, approx. 200 yds from house. I just want to make sure I have plenty of volume and pressure. I have 3 kids and plan to build a 4 BR 3 bath house. I will also have a shop with plumbing and someday plan to have a small orchard and annual garden. Also, unless its detrimental, Im all about overkill !! LOL
  4. #4
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Quote Originally Posted by pharmvet View Post
    How many bathrooms? How many people live in the house?
    What is the pressure at the meter?
    How much higher or lower is the house than the meter?
    You will not loose much pressure to friction loss through the 2" plastic pipe until you get to higher flow rates.
    If you have good pressure at the meter and your house is on the same elevation as the meter, I do not see much gain with a larger meter unless you are going to have a high flow rate then the smaller meter would become a restriction. A 3/4 meter will lose about 7 PSI at a max flow of
    20 GPM. If you need more than 20 GPM or you can't tolerate up to 7 PSI pressure loss then go up a size.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  5. #5
    Join Date
    Feb 2012
    Posts
    85
    Erin, TN
    LS U5030C
    why would you need a larger meter? 1 1/2" line from the meter would be more water then a normal household could use. I ran 2600 ft. from my meter to my house using 1 1/2" and then had to put in a pressure control valve. Tim
  6. #6
    Join Date
    Oct 2011
    Posts
    1,954
    Monrovia, California
    Kubota BX25
    A larger meter will permit more "Volumn" of water to flow at any ONE time.
    The rule of thumb is your meter should not be more than one pipe
    size smaller than your service, in your case a 1.5" meter is required, if
    you have sized the main correctly. If your guessing you could be spending
    money you do not need to spend...
    With a larger meter you are less apt to get things like Shower Shock, as
    in perhaps when the sprinklers come on, and your in the shower a few
    seconds of starved hot or cold water.
    That lil 3/4" meter is a bottleneck on a HUGE 2" line. You will never squeeze
    more water thru it then it will allow, thus you will see what most refer to
    as a pressure drop, when actually the volumn drops. As soon as all
    taps are closed the "pressure" will return to max.
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  7. #7
    Join Date
    Oct 2011
    Posts
    1,954
    Kubota BX25
    Quote Originally Posted by tmeadows View Post
    Thats a whole different story...It is things like that that dictates why
    professionals should do designing and sizing... It is not simple.
    Anything over 80PSI is TO MUCH and
    you WILL spend needless money over the years repairing plumbing if
    you allow the pressure to exceed 80 PSI...Believe it.
    Regards,
    Artisan
  8. #8
    Join Date
    Oct 2011
    Posts
    1,954
    Kubota BX25
    There is no such thing as a "Normal" house. Every water usage tap, sprinkler head, toilet, faucet washer etc et al all have a value , a value
    expressed in fixture units. You NEED to size it PROPERLY or potentially
    have problems...
    Regards,
    Artisan
  9. #9
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,461
    Oklahoma
    JD cut
    Just a guess, based on some experience, but don't be surprised if you find the pressure at your meter is not constant throughout the day, and throughout the year.
  10. #10
    Join Date
    Oct 2011
    Posts
    1,954
    Kubota BX25
    Generally it will rise at night and drop during peak usage hours.
    If you buy a water pressure gauge w/ a tattle tale you can see
    what it does / see the higest it gets while your not watching
    it.
    Regards,
    Artisan
Similar Threads
  1. lets talk water towers
    By jetboat in forum Build-It Yourself
    Last Post: 05-23-2012, 07:11 AM
  2. Replies: 21
    Last Post: 01-03-2009, 08:55 AM
  3. Advice for how to get creek water to the house.
    By scesnick in forum Rural Living
    Last Post: 12-17-2007, 07:30 PM
  4. Need Water Well Advice, Please
    By Gadgetnut in forum Rural Living
    Last Post: 08-24-2007, 07:37 PM
  5. What to use for water line out to detached garage?
    By jim_wilson in forum Projects
    Last Post: 11-01-2005, 09:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
