Page 10 of 21 FirstFirst ... 7891011121320 ... LastLast
Results 91 to 100 of 202
  1. #91
    Elite Member
    Join Date
    Nov 2010
    Posts
    2,867
    out
    kioti ck30
    Default Re: Crickets in the basement - They've got to go!
    I have the solution Mossflowerwoods needs to purchase some green leotards and a flute of course some little pointed booties and a nice pointed cap with a feather. Now play the flute and dance around in the yard. As soon as the crickets start following you could lead them to the chicken yard where they would be devoured. looks like we have a plan. now just to get some cameras to record the event. As you see once presented with a problem i will find a solution. do they have Yuengling beer in "Old Virginia''
  2. #92
    Super Member MossflowerWoods's Avatar
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar (For Sale), CS261, & FS190 + Echo CS400 & rusty old Ranger snowplow truck
    I shall address the "sane"portion first...
    Quote Originally Posted by lockhaven View Post
    Do they have Yuengling beer in "Old Virginia''
    Professor Lockhaven,
    I stock the fridge with Yuengling Black & Tan. It is my daily bread... For special occasions I chill some Guinness.
    WOW, you have an overactive imagination. I might be able to win the $10,000 for funniest home videos with this "solution" but I do not think the crickets will go for it...
    You are something else sir...
    Cracking me up...
    David
    Former Submariner & Army SGT
    2011 Kioti DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, Titan 48" Pallet Forks, & more to come. & 2003 JD LX266 42" deck mower.
    Managing 51 Acres of Virginia hills with ponds & streams, Freshly replanted Loblolly!, riding trails, empty pasture, long gravel drive, garden, & yard.
  3. #93
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Quote Originally Posted by RobertBrown View Post
    If you get a tattoo version, you can keep it on your posterior.
    Yes, I could, but I don't ink so...
    David
  4. #94
    Elite Member
    Join Date
    Nov 2010
    Posts
    2,867
    out
    kioti ck30
  5. #95
    Join Date
    Dec 2010
    Posts
    217
    Quincy IL
    New Holland TC 30
    After reading all the way thru the BS here is what I do every fall in my basement and 36x40 shed. Put hedge balls in every corner and along the wall I use about a dozen for both buildings just put them in the corners. It will amaze you the crickets and also spiders will dissappear. in the spring you will need to discard them as they will rot. Yes i was a skeptic also but it works, I am told there is a natural repellant in the hedge ball.
  6. #96
    Join Date
    Aug 2011
    Posts
    6,101
    Ladysmith, VA
    Default
    Quote Originally Posted by rrrkkk
    What is a hedgeball?
  7. #97
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Quote Originally Posted by MossflowerWoods View Post
    Also called "Brains" or "Monkey Balls"
    Murph
  8. #98
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,725
    Branson, Mo.
    Kioti DK35se Hydrostat
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  9. #99
    Join Date
    Jun 2009
    Posts
    27,725
    Branson, Mo.
    David you might not have any of them where you live, they are fairly common around here. Looking at the 1997 Iowa study, they seem to denigrate the effectiveness as a insect repellant, but the Wikipedia write up seems to say they are effective.. I don't know, but have always heard "old timers" say they are a good insect repellant.
    James K0UA
    James K0UA
  10. #100
    Join Date
    Oct 2011
    Posts
    1,963
    Monrovia, California
    Kubota BX25
    HERE is a link where they write about repelling CRICKETS
    w/ Hedge Balls.
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
Similar Threads
  1. Lime, crickets, and tomatoes
    By MikeA57 in forum General Lawn & Garden
    Last Post: 07-14-2012, 06:01 PM
  2. Water in Basement.....Help
    By scott_vt in forum Rural Living
    Last Post: 03-29-2008, 04:48 PM
  3. Crickets-Crickets-Crickets
    By thcri in forum Rural Living
    Last Post: 09-07-2004, 02:39 PM
  4. Digging out the basement
    By mako652 in forum Projects
    Last Post: 08-11-2003, 12:35 AM
  5. Grasshoppers & Crickets
    By wen in forum Rural Living
    Last Post: 09-18-2000, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
