Results 1 to 3 of 3
  1. #1
    Super Member
    Join Date
    Nov 2003
    Posts
    8,384
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Default Basement window insulation
    I just finished installing the inside window insulation I put on every fall. Have seven Anderson single pane tilt-in basement windows with an external storm pane, and inside I first add 1" of R-5 foam, then a layer of fiberglass R-13, then 2-3 more 1" R-5 layers of foam. Since the entire basement is insulated with stud walls and R-13, I think it makes sense to cover the windows too. I sometimes wonder how much heat loss through the glass my window insulation prevents....anybody know of a source for that information? Thanks.
    Attached Thumbnails Attached Thumbnails Basement window insulation-021-jpg   Basement window insulation-022-jpg   Basement window insulation-023-jpg
  2. #2
    Elite Member Tig's Avatar
    Join Date
    Oct 2006
    Posts
    2,557
    The County, Ontario, Canada
    Kubota, B7100HST-D
    Default Re: Basement window insulation
    Try this
    Run it once with your windows detailed, once without. Compare the difference.
    Steve
    The best things in life are not things.
  3. #3
    Super Member
    Join Date
    Nov 2003
    Posts
    8,384
    Central Michigan
    Quote Originally Posted by Tig View Post
    Try this
    Thank you for the link...I ran it one time with the windows listed as single pane, then ran it the second time with the windows omitted as they are better insulated than the walls when covered...the difference in heat loss between the two was about 4.5%
Similar Threads
  1. Basement Insulation?? Advice??
    By LD1 in forum Rural Living
    Last Post: 03-23-2012, 07:27 PM
  2. Basement Remodel help
    By Doc_Bob in forum Projects
    Last Post: 01-01-2008, 01:03 PM
  3. Window headers, Insulation-live and learn
    By KennedyDiesel in forum Rural Living
    Last Post: 10-27-2005, 10:01 AM
  4. Damp Basement ???
    By MarkV in forum Rural Living
    Last Post: 11-12-2003, 04:12 PM
  5. Digging out the basement
    By mako652 in forum Projects
    Last Post: 08-10-2003, 11:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
