Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,103
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Default Re: What is minimum amount of water needed?
    What part of the country is this?
    May I be the kind of person my dogs think I am,
  2. #12
    Platinum Member BIG DOOLEY's Avatar
    Join Date
    Aug 2012
    Posts
    602
    MICHIGAN
    JOHN DEERE 2320
    A neighboring township just south of us has a large sod farm.
    The sod farm has a large irrigation well.
    During the very dry summers recently the people of the community have run out of water.
    The sod farm pumps so much water from their well that is apparently deeper than most of the surrounding wells.
    It has been a local news topic for many years .
    I guess townships limiting the the water usage has been an issue other places.
    2012 JD 2320, HOMEMADE CANOPY, 54" FRONT BLADE, 54" MID DECK MOWER, HYDRAULIC ANGLE 60" REAR BLADE, QUICK HITCH, STAINLESS FRONT MOUNT SPRAY TANK W/BOOM, 200CX LOADER W/ 61" BUCKET, HOMEMADE BALLAST BOX,HOMEMADE BUCKET GRAPPLE
    1998 "BIG DOOLEY" Chevy K3500 Crew Cab (36.000 miles & counting)
    United Steel Workers Union 12934
  3. #13
    Gold Member
    Join Date
    Sep 2007
    Posts
    492
    Northeast Ohio
    JD 5105, IH-Case 255, JD 3038E
    I was looking at an ad for a piece of land (20 acres) that had a deed restriction for water withdrawal of 5 gpm (5 gallons per minute).
    Is this a surface water (stream) withdrawl rate or well water withdrawl rate? What are your plans for the water? Who put the deed restriction on the property? Government water district or a landowner? Lots of questions that need answered before getting too serious about it.
  4. #14
    Gold Member
    Join Date
    Jun 2011
    Posts
    269
    This is in Eastern Washington State. In the Kittitas County area. Some parts of this area are heavy agriculture growing areas... hay and wheat in some parts, vegetables/salad stuff in others, fruit trees and vineyards in others. Geographically a very large county.
    There is KRD water which is basically like "blue valve" water, irrigation water that comes from irrigation distribution ditches. Domestic water, with limited field/garden/orchard watering comes from wells. They are all metered (or soon will be) by state order. Well water can be used for household water use and for irrigating up to 2 acres of lawn, garden, orchard, vineyards, etc. Not much agriculture-wise. Any bigger agriculture use has to come from the irrigation ditch water, UNLESS you have "senior" water rights deeded to your property.
    In this particular land case, water would come from a well, there is no stream or creek for surface water (which wouldn't belong to the owner anyway, unless deeded to the land years ago).
    I don't know how the "5 gpm" is figured, whether averaged out over time or a max draw per actual minute (how would that be measured?). My understanding is that property owners with the metered wells have to report to the state their water usage (I believe monthly, I could be wrong). 7000 gallons a day would more than likely meet my needs. There is not any KRD irrigation ditch water associated with this land.
    I was just curious how normal that was for a pumping rate for wells (high, low, average). One or more large water storage tanks certainly would be in order. I am not sure a property owner can capture the rainwater off the roofs on his property in that area. The surface water "belongs" to the KRD, unless your property had (senior) deeded water rights before the KRD was formed.
    Water is certainly getting to be a precious commodity.
    Note: "The Kittitas Reclamation District is located in Central Washington in the Kittitas Valley. Here are some brief KRD facts: Approximately two thirds of all the irrigated acres in Kittitas County, approximately 60,000 acres, are serviced by the KRD's 330 miles of canals and laterals. It is the 6th largest irrigation district in Washington State."
  5. #15
    Join Date
    Mar 2010
    Posts
    219
    5gpm average is PLENTY of water. You will want a booster tank to handle peaks if they limit water. They are cheap and easy to install. I'd get a big one and call it good. 5gpm is enough for two showers with low flow heads, but add a toilet flush or dishwasher, etc and you'll have a noticeable pressure drop when taking two showers. At my house these things happen concurrently somewhat regularly, but for most people 5gpm is more than enough.
  6. #16
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    From what you say, the issue isn't a lack of water in the well, it is the use restriction. You can do fine with 5 gal/min. in my opinion, as far as house and limited outdoor use needs go. If the neighbors are reporting monthly, then the restriction may be based on some average usage. Please let us know the details of how the metering works if you get that far along with the land.
  7. #17
    Gold Member
    Join Date
    Sep 2007
    Posts
    492
    Northeast Ohio
    Our old water well partially collapsed after 60+ years. We got by on 1 gpm until our new well was drilled. We did not wash clothes, but were able to do all other household chores. You don't realize what you have until it is gone. Especially water and electric. My wife grew up with cistern water, so she has always used water conservatively. Nice to be back to 15 gpm. 5 gpm should do you well. Good luck.
  8. #18
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,103
    Central Ohio
    Even though we are very careful with water usage I made sure we drilled our well extra deep and with extra good flow--just in case. Also used a higher horsepower motor--same reasoning. You never know and as already stated, you aren't going very far without water.
  9. #19
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    Quote Originally Posted by whistlepig View Post
    We bought a new water softener this fall and it has a digital flow meter on it. We average about 135 gallons a day. Me, the wife, two dogs, and two horses.
    We got a similar water softener recently, and our 2 person household with 3 dogs, but no horses is right around the same usage. 130 to 140 gallons per day. At 5 gpm we would get an entire day's supply in less than 30 minutes. You have plenty of reserve capacity for household use.
    Another way to look at it is our septic system is extra large -- we have 4 bedrooms total, and they required a system capable of handling 350 gallons per day. That works out to just under 0.25 gpm. 5 gpm is 20 times what you would need for a family of 8.
    The real restriction is that you will be limited in how much you can irrigate. Probably about 1 acre. Do you really want to cut more than one acre of grass?
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  10. #20
    Join Date
    Jul 2012
    Posts
    91
    Goochland, Va
    Bobcat 773
    Our well refreshes at 6gpm - had to go to 805 ft to get better than 3gpm (judged inadequate). 5gpm isn't bad - it will handle everything you need unless you start a big garden.
    We have a column of water of about 500ft above our pump which yields about 800 gallons in the well - so I am not worried about running the well dry.
    One thing to bear in mind is that if you run your pump dry you will earn yourself a few days of hard work to replace it. We just finished replacing our deep well pump.
Similar Threads
  1. What is the minimum trailer needed to safely haul a bobcat?
    By dirt ditch in forum Bobcat Construction Equipment
    Last Post: 05-09-2012, 07:14 AM
  2. How do you determine amount of rebar needed?
    By soilsailor in forum Projects
    Last Post: 02-17-2012, 12:32 AM
  3. How to calculate the amount of SCA/DCA needed.
    By DieselPower in forum Oil, Fuel & Lubricants
    Last Post: 04-11-2011, 05:55 PM
  4. Minimum horsepower needed
    By moloss in forum Buying/Pricing/Comparisons
    Last Post: 05-03-2007, 10:23 PM
  5. Replies: 2
    Last Post: 02-04-2007, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
