Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Gold Member
    Join Date
    Jun 2011
    Posts
    259
    Default What is minimum amount of water needed?
    I was looking at an ad for a piece of land (20 acres) that had a deed restriction for water withdrawal of 5 gpm (5 gallons per minute). Doesn't seem like much water at first, but that is 300 gallons per hour and 7200 gallons per day at that pumping rate. Does that sound too restrictive?
  2. #2
    Super Member
    Join Date
    Sep 2000
    Posts
    9,019
    Triangle Of North Carolina
    JD 4700
    Default Re: What is minimum amount of water needed?
    Quote Originally Posted by edlegault View Post
    Interesting that the deed has a 5 GPM water restriction...
    In my area, many homes are lucky to get a well that produces 5 GPM. We have 15 GPM and a neighbor has over 30 GPM but we are both very much the exception. The other neighbors are in the 5 GPM range. Best I can tell, our pump is rated at 5 GPM.
    Our shower and kitchen faucet use less than one GPM. I have measured it. The toilets are low flow, the front loading clothes washer and dishwasher use around 10 gallons for a load. I figure, worst case, we use 200 gallons a day for the house. We will water the garden if we need too though but we have not had to water very often.
    How would anyone know how much water you are using? That would concern me more than actually using 5 GPM.
    Later,
    Dan
  3. #3
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    Kubota B7800 with FEL
    I can't comment about the 5 gpm but I do know that when they drill wells in our area they drill deep enough so that the well flows 50 gpm.
    ........Shoot this thang! Have mercy this thang is killin' me. Just shoot up here amongst us. One of us has got to have some relief..............
    jerry clowers-a coon huntin story.
  4. #4
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    We bought a new water softener this fall and it has a digital flow meter on it. We average about 135 gallons a day. Me, the wife, two dogs, and two horses.
  5. #5
    Gold Member
    Join Date
    Mar 2012
    Posts
    326
    NSW Australia
    Tractors16-600hp Farm & Earthmoving Equip, Trucks etc.
    All depends on what you want to use the water for :-
    - Domestic use a family of 4 with all mod cons (dishwasher etc) with go through c.1200gallons/week
    - Agricultural irrigation 5GPM sure isn't going to water 20acres constantly
    Often water restrictions are applied to preserve the water source quality,flows & volume as water isn't an infinite resource, &/or to limit the salt table rising & devalue the viability of the land through over irrigation........................either way I'd be doing the research to find out the reasons, though it wouldn't necesarily dissuade from purchasing good acres
  6. #6
    Join Date
    Jan 2009
    Posts
    3,564
    Preble County, Ohio
    On the flow this is what you may getting into: If you are taking a shower and someone flushes the toilet you may get scalded. If the washer is filling all bets are off for water anywhere else in the house. Not saying that 5 gpm isn't sufficient. But we have lived at a place that had a poor flow of water. These were the issues that we dealt with.
  7. #7
    Join Date
    May 2011
    Posts
    697
    Trent Hills, ON
    Kioti DK40SE HST
    Quote Originally Posted by whistlepig View Post
    I put in a large pressure tank and have 3/4" pipe leading to a manifolds with 1/2" outputs don't really have a problem with water temps changing with flow rates and our well can only sustain 5 gal/min.
    5 gal/minute can fill up quite the reserve tank if the OP has uses that need more than 5 gal/min instantaneous flow for some reason.
    2011 DK40SE HST
  8. #8
    Gold Member
    Join Date
    Jun 2011
    Posts
    259
    in regards to the 5 gpm water max restriction -- It is my understanding that all new wells (and most old wells) in that area of that state have flow meters on them.... I could always pump 24x7 as necessary to keep big water tank filled...
  9. #9
    Gold Member
    Join Date
    Mar 2012
    Posts
    326
    NSW Australia
    Poor water volume can be readily overcome by the addition of c.1000+gal tank that auto fills from the well, maybe even plumbed into your rain gutters too & then is either gravity fed or pressure pumped to the house - used this for many years, just like mains water pressure only tastes better.
  10. #10
    Super Member dave1949's Avatar
    Join Date
    Apr 2009
    Posts
    5,900
    Industry, Maine
    New Holland TC40
    It also depends on how that restriction is measured. If it is truly a 5 gal. per minute limit, or does it mean average use that doesn't exceed 5 gal/min?
    We lived on a well rated at 7 gal/min for 12 years with no problems, but I'm sure the pump was pulling more than 5/gal per min. when it refilled the pressure tank. It's really comparing two different things unless you know exactly how the 5 gal/min is meant.
    The well driller told we wouldn't have any problems, just don't do lots of lawn watering in summer. That advise held up.
    “It is a great thing to know the season for speech and the season for silence” ― Seneca (4 BC - 65 AD)
Similar Threads
  1. What is the minimum trailer needed to safely haul a bobcat?
    By dirt ditch in forum Bobcat Construction Equipment
    Last Post: 05-09-2012, 07:14 AM
  2. How do you determine amount of rebar needed?
    By soilsailor in forum Projects
    Last Post: 02-17-2012, 12:32 AM
  3. How to calculate the amount of SCA/DCA needed.
    By DieselPower in forum Oil, Fuel & Lubricants
    Last Post: 04-11-2011, 05:55 PM
  4. Minimum horsepower needed
    By moloss in forum Buying/Pricing/Comparisons
    Last Post: 05-03-2007, 10:23 PM
  5. Replies: 2
    Last Post: 02-04-2007, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
