Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Gold Member
    Join Date
    Jun 2002
    Posts
    471
    Upstate NY
    B2150DT / Oliver OC-3
    Default Re: Quick high-tensile fence repair
    If you only need a few quick splices or repairs, the gripple is a quick cheap solution. These should be around locally. I've seen these hold when a tree falls and breaks the wire somewhere else. Gripple 1 Each
    Marty
  2. #22
    Super Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    6,048
    Central Texas, Jarrell
    Kubota Grand L5030HSTC
    Don't forget to stock up on wire strainers and a handle.
    Quote Originally Posted by dmccarty View Post
    I will try my local farm store and see if he has the stuff. I bought my HT wire and such from him. If he does not have it, off to Tractor Supply.
    Later,
    Dan
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  3. #23
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by texasjohn View Post
    If you wrap your strainer handle in several layers of electrical tape, then you can adjust the tension out in the field without having to de-energize the fence.
  4. #24
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default
    Quote Originally Posted by joshuabardwell
    Wearing Muck boots works too, usually that is.
    Quick high-tensile fence repair-image-210386172-jpg
    My new charger came with a fault finder / remote control. I can turn the power off from anywhere along the line by touching the remote to the wire and holding down the button. It is pretty cool and very handy!
  5. #25
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by DT86 View Post
    I have not found that to be the case. I wear muck-boots all the time, and I can't tell you how often I have been shocked by my fence.
    Is it a Speedrite? I ask because, as far as I know, they're the only ones who have that remote on/off function. I would really love to find someone who made an external box that you plugged the energizer into that would add remote on/off to the fence after the fact. As much as I would like that feature, I can't justify buying a whole new Speedrite energizer just to get it.
  6. #26
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Default
    It is a Stafix. The same company, TRU-TEST makes or owns both brands. I had the older model with out the remote but the charger stopped working. I sent it off to be fixed locally but had to have one in the mean time so I upgraded. Now I have a spare.
    Which Mucks are you wearing? I buy the green ones with the orange inside. The name slips my mind at the moment.
    I have never received a full power shock with them on and my fence is HOT. Dad always said "It brings a tear to their eye and their knees to the ground"
  7. #27
    Join Date
    Oct 2005
    Posts
    6,048
    If you use an electric fence charger, you need a Smartfix fence tester, by Gallagher. Saves sooooooooooooo much time figuring out where a fence problem is and where to look for the problem. Yes, costs $ but saves soooooooooooooooo much time it's worth it.
    It tells you
    Voltage on fence
    Amps being delivered by fence
    Direction of flow of amps.
    Using it, you don't have to cut the fence off .... it leads you directly to the short/broken wire....then you can turn fence off (if needed) once and fix it.
    Wish I had discovered it years sooner....cuts hours off of my fence fix time...There are some other brands, but be sure to get one that shows voltage, amps, and direction of flow.....those 5 light testers I used for years are stone age compared to the Smartfix.
    Just FYI....nobody asked....but you need to know.
  8. #28
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Default
    ...It tells you
    Voltage on fence
    Thats the way my old one worked, you are right it is a time saver.
    The new one does all that plus cuts the power on/off from anywhere on the fence.
  9. #29
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    To tell you the truth, they are pull-on galoshes, but not Muck brand. I was using the phrase more generically, which, it seems, may make a difference.
  10. #30
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Yes, yes, yes a thousand times yes. If your fence tester does not tell you amps and direction of current flow, you are missing out. It costs maybe $120, but it will more than make it up with the number of hours you don't have to spend walking the fence looking and looking for where the short is. I wrote a blog post some time ago about the difference between different kinds of fence testers. Here's a link:
    Electric Fence Testing Meters | Jack-Booted Liberal
    The short version is that, with a "fault-finder" tester that shows amp direction, you can simply "follow the arrow" to the location of the short. Just keep walking until the current flow changes direction, and then you know you passed the short. Otherwise, it's just trial and error. I honestly do not know how people maintained electric fences without these.
Similar Threads
  1. High tensile knot.
    By pickeringchris in forum Build-It Yourself
    Last Post: 05-16-2012, 06:43 PM
  2. Will a splice on high tensile wire hold up?
    By warhammer in forum Projects
    Last Post: 02-03-2010, 01:09 AM
  3. 50 acres of High tensile
    By Gizmo36 in forum Projects
    Last Post: 03-10-2009, 06:39 PM
  4. Hi Tensile Fence
    By oddtoad in forum Projects
    Last Post: 07-03-2008, 09:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
