Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
  1. #11
    Platinum Member nikdfish's Avatar
    Join Date
    Oct 2010
    Posts
    690
    Person Co. NC
    John Deere 3038E & 1025R FILB
    Default Re: Cell Phone Signal Booster
    Another approach is to go with a commercial quality long range cordless phone that would connect to either a land line or cellular base station. Not cheap, but there are models that claim up to 3000 acre coverage (open line of sight) or 12 stories worth of building. Check out EnGenius & their Durafon 1x product.
    Nick
    2010 John Deere 3038E w/305 FEL
    Frontier RC2060 Rotary Cutter, Frontier BB2060 Box Blade, Jinma 6" Chipper from Ranch Hand Supply, TSC Tarter 5' Rotary Tiller, Middle Buster, ASC Keulavator Hiller/Bedder, Caroni 59" Finish Mower, TSC 6' Landscape Rake, TSC 6' Back Blade
    2010 Gator CX
    2013 John Deere 1025R FILB w/ Bro-Tek thumb & ripper
    Retired FBOP NRA Life, Amateur Radio KK4WMX (General Class)
  2. #12
    Super Member clemsonfor's Avatar
    Join Date
    Sep 2009
    Posts
    8,541
    Greenwood Co., SC
    Yanmar YM2000
    Quote Originally Posted by Cagley View Post
    It's not really possible to boost a signal in an outdoor space. The good news is that it's very possible to boost it in buildings (even large ones) and in vehicles like a truck or tractor. The problem with trying to transmit a boosted signal outside is that it increases the possibility of interference with either the donor antenna or with the carrier's tower, both of which will cause the signal booster to shutdown. If you have a strong booster in a building, you might get some coverage outside but not a lot.
    Knowing that you really can only use cell phone signal boosters/repeaters in a building or vehicle, what do you think would be ideal for your situation? Wilson has some really good mobile products that are great for a truck or tractor. The Wilson Sleek 4G-V and the In-Vehicle kit are two I've used.
    Buildings are a bit more tricky since it depends on the square footage, construction, and the strength of the signal outside. If you let us know a bit more about the buildings you need to boost signal it, we can come up with some recommendations.
    Advertisement? First post touting a certain brand after it was just recommended?
    I smell sales rep, internet media guy?
    YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
    1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
    1991 Javalen 17ft w/same year 150 Johnson GT
    Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
  3. #13
    Join Date
    Oct 2011
    Posts
    2,193
    Olalla WA, Kitsap Peninsula, West of Seattle
    Kubota BX25
    We also have Verizon service. When we moved to the country 23 years ago we found we were in a fringe area with spotty reception like yours. Verizon has a network extender unit, ours is Samsung. It connects to our internet service router so we get all cell calls over the internet vice the cell towers. We have 4 bars all over the property (21 Ac). NBe sure you go to a Verizon company store not one of their franchise retail stores/kiosks. I get excellent service from Verizon but the franchise stores are short in the knowledge base.
    Ron
  4. #14
    Join Date
    Oct 2011
    Posts
    184
    Greene, NY
    TL80a, Ford 4000, Super H, F 12, F14
    Ron, Thanks - that sounds like a possibility. I'd be very happy to just get service on 2 acres around the barn!
    Bob
  5. #15
    Platinum Member wcampbell47's Avatar
    Join Date
    Jul 2009
    Posts
    706
    Texas Coast
    Kubota B7510 and L3901
    Quote Originally Posted by Sawdustsmb View Post
    Well here's my problem. If I'm in the top of the hay mow I get great several bars, 200 feet up in a field one bar, over in the valley and in the woods 3 bars. Around the barn (or in the haymow when there is no hay ) it might ring in - or not ! I've looked at signal boosters but they all advertise use inside homes, offices, etc. So my question is has anyone tried one of these boosters to get service outside the buildings as well as in some of the farm buildings? I have 3 bars on top of the 25' electric pole next to the tractor garage. By the way it is verizon service. Any thoughts would be appreciated.
    thank you,
    Bob
    A cell phone signal booster can do wonders if you have the right equipment and can get a directional antennae pointed at the tower and there is enough of a signal to boost. There is some science to installing one. Just sticking up an antennae and hoping it works will most like yield unsatisfactory results. Go to CellReception.com and key in your city or zip code. The map will be populated with known cell towers in your area. You can try a different phone, but if there is not sufficient signal you have just wasted your money. The Wilson web site has a tab to find certified installers in your area. A certified installer can help you determine if a booster will actually do you good. A good booster will amplify signals from all services. Nextel is going away so don't include that service. Then it becomes which tower is sending the strongest signal in your area. I have saved a number of marriages in my area by doing a good install. At least read up from the Wilson web site. The attached thumbnail shows Verizon towers near Greene, NY.
    Attached Thumbnails Attached Thumbnails Cell Phone Signal Booster-greeneny-jpg
    Caution: Some of my posts may be politically incorrect.
    Kubota B7510 & L3901
  6. #16
    Join Date
    Oct 2011
    Posts
    184
    Greene, NY
    Icould be getting signal from any of those three towers. Is there a way of knowing which one I'm connecting with or is that just trial and error? Surprised anyone gets signal from Verizon!! Maybe I should work on convincing them to put a tower on my "hill"
    Bob
  7. #17
    Join Date
    Oct 2011
    Posts
    2,193
    Kubota BX25
    Bob
    That network extender I mentioned does exactly that. Puts a 5,000' radius cell tgower on your property. It is password protected also.
  8. #18
    Join Date
    Jul 2009
    Posts
    706
    Texas Coast
    Bob
    I would say the one with the strongest signal (obviously). Some phones can be put into "test mode" where you see a number indicating signal strength. Using that walk around the property and see if the strongest signal is coming from one of the displayed towers. A -65db is a great signal, -100db and you might be able to send text messages. The solution I have been working with is specifically for buildings, however there are booster packs for cell phones.
  9. #19
    Join Date
    Sep 2009
    Posts
    8,541
    Greenwood Co., SC
    Yanmar YM2000
    Quote Originally Posted by wcampbell47 View Post
    Most carrierrs have a clause that you can get out of a contract in say 30 days if your not satisfied with reception at say your house.
  10. #20
    Join Date
    Sep 2009
    Posts
    8,541
    Greenwood Co., SC
    Yanmar YM2000
    I went to the site, put in my town and see nothing, well thought it was cause regardless of carrier there is no signal at the house. So i clicked on your picture,... where are the towers adn coverage in the area posted i see nothing but a map?
Similar Threads
  1. Cell phone booster
    By radman1 in forum Rural Living
    Last Post: 08-18-2011, 12:27 AM
  2. Cell Phone - Droid X Smart Phone
    By Gale Hawkins in forum Related Topics
    Last Post: 11-05-2010, 08:22 PM
  3. cell signal booster???
    By tungularafishcamp in forum Rural Living
    Last Post: 11-03-2010, 02:54 PM
  4. Cell phone
    By coachgrd in forum Rural Living
    Last Post: 04-12-2004, 07:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
