Results 21 to 30 of 46
01-07-2013, 12:41 PM #21
Re: Cell Phone Signal Booster
I typed in Greenewood SC. Am I at the right place? The red dots are cell tower locations. Filter them for a specific cell service provider by checking the provider along the top. Cell phone signals are affected by obstructions. Mountains, trees, buildings. Building materials can affect your signal as well. Metal roofing, metal studs. The new roof decking with heat shield material applied. In order for the booster to do some good you have to locate it where there is some kind of signal. In the flat land where I live a viable signal can only reach out about 21 miles.
Caution: Some of my posts may be politically incorrect.
Kubota B7510 & B3200
01-07-2013, 02:53 PM #22New Member
- Join Date
- Jan 2013
- Posts
- 8
- Location
- Mayville, NY
- Tractor
- Kubota
01-07-2013, 02:59 PM #23New Member
- Join Date
- Jan 2013
- Posts
- 8
- Location
- Mayville, NY
- Tractor
- Kubota
01-07-2013, 04:02 PM #24
YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
1991 Javalen 17ft w/same year 150 Johnson GT
Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
01-07-2013, 04:04 PM #25
01-07-2013, 04:07 PM #26
And here is a link to my map of my zip, filtered i think for verizon...
Bradley Cell Towers and Coverage Maps - CellReception.com
It shows no towers even in greenwood, which i know there is cause there is a verizon store there in town so there is some towers there?
My personal cell is alltell, which is very limited maybe half the calls will go through at my house that call me and ones i make maybe 25% can connect allthouth you cant really hear anything, and texts take forever to send. Verizon is worse, basiclly zero signal and att about the same and no one else has a bit of signal.YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
01-07-2013, 04:08 PM #27New Member
- Join Date
- Jan 2013
- Posts
- 8
- Location
- Mayville, NY
- Tractor
- Kubota
01-07-2013, 04:26 PM #28
There was a hilarious string of them in the trailer section. One guy complained about X brand of trailer and then another said something then all of a sudden for a week or 2 there kept poping up a person saying how great brand X was then a reply of a person saying how cheap they trailer X was, then another praise. It was like damage control overload for the company then a competitor slamming them again. I pointed it out many times as did others and it continued for a few more posts weeks later!
01-07-2013, 04:38 PM #29New Member
- Join Date
- Jan 2013
- Posts
- 8
- Location
- Mayville, NY
- Tractor
- Kubota
01-07-2013, 04:48 PM #30Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,467
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
I was just at Verizon today asking about the boosters.
They say it will work only if you have internet already and can connect the booster to the cable box, and essentially re-transmit the signal. The higher you can get the transmitter, the more range you have. It's been 53 years since I had wave guide theory. Line of sight ,correct.
Is it also true the higher you place the Mifi the better signal you will have.
Cost is $199. for the boosterJ.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
Similar Threads
Cell phone booster
By radman1 in forum Rural LivingReplies: 26Last Post: 08-17-2011, 11:27 PM -
Cell Phone - Droid X Smart Phone
By Gale Hawkins in forum Related TopicsReplies: 19Last Post: 11-05-2010, 07:22 PM -
cell signal booster???
By tungularafishcamp in forum Rural LivingReplies: 19Last Post: 11-03-2010, 01:54 PM -
Cell phone
By coachgrd in forum Rural LivingReplies: 6Last Post: 04-12-2004, 06:25 PM
