Results 21 to 30 of 30
01-21-2013, 07:44 AM #21New Member
- Join Date
- Dec 2009
- Posts
- 17
- Location
- west central missouri
- Tractor
- 1974 IH 574
Re: Help with SPECIFICS of the plan for 12' x 16' Horse Run-In shed...
As a retired builder, I built a lot of pole sheds (& barns) over the years. If you are going to use it for livestock, use 5x5 or 6x6 posts. 4x4 posts are too small to use for livestock buildings. They can't stand up to the pressure of a animal rubbing against them. Opening size no less than 10 ft. Post spacing on the rest of the walls 8 ft. Header size- up to 10 ft at least use two (2) 2x8's. Any opening wider than that - two (2) 2x10's or 2x12's (depending on there you live and how much snow you get.) Back walls - no less than 8 ft. Front wall- at least 12 ft. This would give you a 3/12 pitch roof. Steep enough that snow would slide off.
The problem I've seen with the shed 'kits' is that you get #3 or lesser grade lumber and not quite enough lumber to do the job right. This comes from people who brought the kits and built the shed themselves.
01-21-2013, 07:52 AM #22Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
- Kioti DK50SE HST w/FEL, John Deere LX266 & STX38 Mowers. Stihl MS290 20" bar, & FS190
Former Submariner & Army SGT
2011 Kioti
DK50SE HST, KL-401 FEL w/72" bucket, tooth bar, & Ratchet Rake, 2 rear remotes, canopy, WR Long RBG72 Grapple, Woods BB72X cutter & TSG-50 stump grinder, TSC PHD, & more to come. Mowers 2003 JD LX266 42" deck mower, & old JD STX-38 (12.5 hp).
Managing 51 Acres of Virginia hills with ponds & streams, mature market timber, riding trails, horse pasture, long gravel drive, veggie garden, & yard.
01-21-2013, 07:56 AM #23Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
MoTreeFarmer,
I'm looking at a 12' span, and the shed will be 16' deep, so I would have 3, front, middle, and rear 8' spacing.
That means two 2x10's for each, and do I nail them together into a 4x10, or do I put one on each side of the 5x5 or 6x6PT Post?
What do I run for purlins?
Thanks in advance,
DavidFormer Submariner & Army SGT
2011 Kioti
01-23-2013, 03:52 PM #24Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
You guys are awesome and while on the plane Monday I got a good start on drawing out plans for the run-in shed.
I have some new questions...
Right now if I have an 8' back height, and a 3/12 pitch, the front will be approx 12', that seems REALLY high... If I put a ridgeline in towards the front, I will be forced to build my own trusses, right?
Given 12' width, can I afford to go to an 8' opening, allowing 2 side walls on the front at 2' wide each.
I assume the rafters (two 2x10's , nailed together) must go directly on top of the post, so I need to cut the posts down to allow for the height of the rafters and purlins?
How big to make the purlins given a 2' spacing? 2x2 or 2x4 on end?
Should I plan for the roof to overhang on the front and back? How much? How about the sides?
I am planning to set the poles 3' deep, I am looking for 5x5 posts, given doubled 2x10 rafters, do I need a post in the middle of the middle an front? Given a post in the middle of the rear, I can reduce the rafter size, right?
I'm sure I have more stoopid n00b questions...
Thanks in advance,
2011 Kioti
01-24-2013, 07:00 AM #25New Member
- Join Date
- Dec 2009
- Posts
- 17
- Location
- Tractor
- 1974 IH 574
01-24-2013, 07:42 AM #26Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
Thank you.
Next question... Given that I put one 2x10 on each side of the 5x5 post, I need to make sure they match up to the pitch of the roof, right, so if I'm doing a 3/12 pitch, I need to cut the post and one board will be higher than the other, to ensure contact with the purlins and support for the load of the roof.
The 2x10s are the HEADERS, not Rafters as I called them... Got it.
Right?
(I hope I am making sense...)
2011 Kioti
01-24-2013, 08:18 AM #27New Member
- Join Date
- Dec 2009
- Posts
- 17
- Location
- Tractor
- 1974 IH 574
When I was doing the rafters, I would cut the tops & bottoms of the rafters like a person would cut one for a house. If this is something that you don't want to do, I suggest putting the 2x10's on the outside of the posts, set a rafter by each of the posts, then put the 2x10's on the inside, pushing them up to the bottom of the rafter and nailing them there. Then you can finish putting up the rest of the rafters and cut the top of the post off flush with the top of the rafter. (I used a chain saw for this, also cut the post with a slope away from the post). If you don't have a chain saw, you can use a sawzall (recepticating saw). It's slower but you have more control.
01-24-2013, 09:31 AM #28Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
I think I am following you. I won't be using my 20" stihl to trim boards I hope...
I need HEADERS to cross the span and they hold up the RAFTERS which will run across the 3 HEADERS. On top of the RAFTERS I will need PURLINS to attach the metal roofing too. In the end I will have a grid, all held up by the HEADERS supported by the poles...
Right?
2011 Kioti
01-24-2013, 09:35 AM #29Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
My concern about notching the rafters to fit on the headers was that might weaken them, make them subject to splitting?
My pencil drawing makes me think I do not need Purlins, I can attach metal roofing straight to the rafters? Is that wrong?
2011 Kioti
01-24-2013, 09:39 AM #30Elite Member
- Join Date
- Aug 2011
- Posts
- 4,836
- Location
- Ladysmith, VA
- Tractor
2011 Kioti
Similar Threads
Building Horse Fence & Run-in shed in the Winter in VA? What to look out for?
By MossflowerWoods in forum ProjectsReplies: 47Last Post: 03-17-2013, 04:21 PM -
Run-in shed for a horse... plans?
By Anonymous Poster in forum Rural LivingReplies: 10Last Post: 07-23-2012, 10:24 AM -
12' x 24' Run In Lean To Shed Row HELP???
By Paddle Fly in forum ProjectsReplies: 2Last Post: 09-01-2010, 12:23 PM -
Any one got ideas for a small 12' long by 8' wide storage shed?
By deereboy72 in forum ProjectsReplies: 9Last Post: 04-01-2009, 03:28 PM -
Interesting Horse Run-In Shed Project!
By Tonester in forum ProjectsReplies: 9Last Post: 11-01-2003, 06:19 PM
I know, too many projects...).
