Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 76
  1. #21
    Join Date
    Jun 2010
    Posts
    2,028
    Myrtle Creek, Oregon
    Kubota l3130
    Default Re: Seasoning a cast iron skillet....Tips please
    Quote Originally Posted by joshuabardwell View Post
    This may be dumb, but why not a flap wheel on an angle grinder?
    Be prepared to buy a lot of flap wheels.
  2. #22
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by Larry Caldwell View Post
    Can you elaborate? I can take off a heck of a lot of mild steel with a single flap wheel. Is cast iron that much harder?
  3. #23
    Join Date
    Jun 2010
    Posts
    2,028
    Kubota l3130
    Yes, cast iron is much harder than mild steel.
  4. #24
    Super Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    7,778
    Hudson, Maine
    2003 NH TC30
    In our family we never used anything but cast iron for frying on the stove. I even have one large frying pan that we had as a kid. The pans go through the dish washer, brillo pads, steel wool pads. We cook in butter, sometimes olive oil or bacon fat. We cook on gas. Except when the pan is new- I never worry about seasoning, I just use it. Always have. -Great cooking surface. Nothing beats cast iron. Some pans have come from flea markets - cleaned them and used them.
    NH TC30, 7308 loader, 7' snowbear plow, 5' hiller, 5' tillovator (agrisupply), International Agritech 5' towable Bushhog. dumping carryhall, camo brush trailer, 8 hp Trencherman backhoe, International disk harrow, International single plow, Sears ZTL 7000, 8hp Roto Hoe Shredder'nChipper, CubCadet 524 snow blower, CubCadet rear tine tiller, working forge
  5. #25
    Super Member SPIKER's Avatar
    Join Date
    Jun 2002
    Posts
    5,000
    Ohio, Jeromesville, Ashland County
    Jinma 284
    next time you are Baking your Bacon stick your cast iron UNDER the bacon instead of the drip pan you talked about. Bacon and Lard (aka Crisco) are your BEST bets for seasoning followed up by Canola oil. Peanut oil will work but lots of people have allergies to that on top of the temps that peanut oil "cooks" at is a bit higher. we use most extensively 2 cast iron pans, and a stainless deep pan & skillets the SS for soups and acidic stuff while the cast for everything else including EGGs about the only things we ever have STICK are fried taters (we try to use as little oil as possible in them and just browning taters will burn to pan) and use olive oil in them for taste which is not very good seasoning oil for cast but good for cooking in.
    The 12" deep skillet we do Old Style Southern Fried Chicken in it which makes it 100% non stick for weeks. we also have a 10" flat round skillet that we make garbage omelets in and only thing that might stick a bit would be some of the cheese.
    Cleaning of the pans should be done regularly but not when hot, I ALWAYS let them cool as the oils and burnt or stuck on stuff seems to come off much easier. I also coat them well when hot with oil (bacon grease or canola) when cooling down if something dry was cooked in it. I scrape mine with the SS Spatula rounded edges and flexible so not a lot of pressure is subjected to the surfaces. I also wash mine regularly & use plastic scrubber with some dish soap (dawn) to remove the surface food bits and toss it onto the stove to dry it. I add some canola spray or a coat of bacon grease (after it is dry) and still heating and bring it up to a high heat for about a min & shut it off the grease/oil stays on until next cooking cycle.
    One of the best pans I've had was made by "Imperial Ireland" & was originally a NON-STICK with a ceramic coating that had been chipped & tossed in garbage by my sister-n-law. I took it and sand blasted the ceramic that was chipped off and seasoned it. It was maybe 10" with a 10" wood handle with sloped sides instead of the flat sides like most US made ones. Eggs in it was like a non-stick commercial slide em around & right out onto a plate... the people I sold my house to wanted to move some stuff in while I was moving stuff out. & the pan got left there & when I went back for it the young woman said she tossed it out as it was OLD & GREASY ... ug
    Mark
    I may remember why I went to the other end of the shop, I'm just afraid once I get there I'll forget how to get back!
  6. #26
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,694
    JD, Massey, Kubota, Case
    Default
    My best seasoned pan is a Wagner deep sided chicken fryer that my Mom used as a donut fryer. My Mom made a lot of donuts when I was growing up needless to say.
  7. #27
    Veteran Member General Lee's Avatar
    Join Date
    Oct 2009
    Posts
    1,323
    Mid-Atlantic
    Kubota, L4400, BX1870
    I'm gonna start keeping my eye out for some wagner and griswold pans/skillets.
    Kubota L4400 - Land pride rear scraper blade, 6 foot landscape rake, 72'' Frontier Box Blade, Land Pride 60'' finish mower, Land Pride Q/A pallet forks, County Line Carryall built to haul and loaded R-1's
    Kubota RTV500
    Kubota BX23S
    Previous Tractors: 1978 B7100, 2009 B3200, 2013 BX1870
  8. #28
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Quote Originally Posted by General Lee View Post
    In my part of the Country, they are available at local farm auctions, where one or both of the previous owners are deceased. Best wishes.
    The PUPIL who does not surpass his Master, fails his Master.
  9. #29
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    Forget the oven, it doesn't get hot enough to season cast iron properly. Coat that sucker in lard, then fire up the charcoal grill and let it bake. The hotter the better. Assuming that you have a charcoal grill.
  10. #30
    Gold Member burnieman's Avatar
    Join Date
    Feb 2012
    Posts
    484
    Trinity County California
    John Deere 955 With 70a Loader and 7 backhoe, John Deere 110 Backhoe
    Default
    An old Cajun trick for seasoning a cast iron skillet is transmission fluid. We've used it for years in the swamp. Foods don't stick and cleanup is a breeze. My uncle toufee uses hydraulic fluid but I don't . Not sure how healthy that is.
Similar Threads
  1. cast alum vs cast iron
    By fluffyone in forum Kubota Owning/Operating
    Last Post: 12-28-2017, 10:42 AM
  2. Cast Iron
    By MasseyWV in forum Parts/Repairs
    Last Post: 02-12-2012, 10:14 PM
  3. Cast iron
    By jcottons in forum Welding
    Last Post: 12-22-2011, 03:36 PM
  4. Welding Cast Iron
    By dliston in forum Welding
    Last Post: 08-11-2005, 05:28 PM
  5. WELDING CAST IRON
    By buster in forum Parts/Repairs
    Last Post: 03-09-2005, 07:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
