Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. #21
    Platinum Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    564
    Meridian, OK
    Toolcat 5610 F V417 Versahandler TORO+Loader
    Default Re: Water Well Pump Monitor???
    Quote Originally Posted by Willl View Post
    You really need to get out there and introduce yourself to your well system.
    Haven't needed to until my wife left the water on, filling the horse water tank.
    I did check it out today. The pressure tank is in the 6" casing, the pressure switch is about 3' down from the top. I didn't see a rope or anything to pull the pump with. Can't see anything below the pressure switch, except the pvc pipe it is on.
    Water Well Pump Monitor???-p2170001.jpgWater Well Pump Monitor???-p2170002.jpgWater Well Pump Monitor???-p2170003.jpgWater Well Pump Monitor???-p2170004.jpg
  2. #22
    Join Date
    Feb 2013
    Posts
    564
    Meridian, OK
    Quote Originally Posted by SPYDERLK View Post
    Just an appropriate fitting probably to mate with one in an existing joint at washing machine, sink, toilet, ice maker, etc.
    Thanks, I did think of that after I answered your post. The water heater would be the best place.
    I did find something that would do what I to do. It is an AC current sensor relay. I can wire the light to it or a wireless transmitter to a light in the house, or both.
    Thanks to everyone for your ideas.
  3. #23
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,344
    Northwest, WA
    Quote Originally Posted by Xfaxman View Post
    Not saying it ain't for sure, but just doesn't sound right.
    A pressure tank would be of some considerable size. Just don't see how you could fit one in a 6" pipe.
    ::Sent from a standard desktop keyboard::
    My Photobucket
  4. #24
    Join Date
    Feb 2013
    Posts
    564
    Meridian, OK
    Here is one: In-Well Technologies - Who We Are
    Do a search online for "pressure tank in the casing", and learn like I did, since I had never heard of it before also.
  5. #25
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,344
    Northwest, WA
    Interesting, with draw down sizes being so small I'm guessing the pump runs more like a demand type system ?
    My Photobucket
  6. #26
    Bronze Member ghenges's Avatar
    Join Date
    Apr 2012
    Posts
    84
    Greensburg PA
    Farmall
    I need a way to know when the 240 volt water well pump is running.
    Is there some wireless device that would turn on a light in the house when the pump is drawing current? There is no well house, We were told the pressure tank is in the casing, so I don't know if I can get to the pressure switch.
    The pump is on a breaker box about 50 feet from the house. The power to that box runs underground from the meter at the transformer box that is fed by an underground line from the power pole. That breaker box feeds two other buildings.
    Thanks
    I will guarantee you one thing:
    A few months after you install an indicator light, you will forget about looking at it.
    I know, I put a monitor light on our pump when I built our house, the only time it got noticed is when a guest would occasionally ask what "that light" was for.
    If you want a more practical monitor light, install a pressure switch on the water line where it enters the house, then set it slightly below your pump's cut-in pressure.
    When the light comes on you'll know you have a problem because it is something you haven't become accustomed to ignoring..
    "I know the end of humanity is near when my tractor comes with a place to store and plug in a cell phone, but no tool box" -- God's Country
  7. #27
    Join Date
    Feb 2013
    Posts
    564
    Meridian, OK
    I have no idea how big the tank is, but the pump just happened to come on while I was looking down the casing, it ran longer than I expected. I need to put the pressure gauge on the faucet there and check the run time.
  8. #28
    Join Date
    Feb 2013
    Posts
    564
    Meridian, OK
    Quote Originally Posted by ghenges View Post
    Yep, good advice.
    A light wired that way would tell me that the pump wasn't running when it should be running. I would find that out without a light the next time I opened a faucet and saw low or no flow.
    If there is a leak or a hydrant left open, I think this pump will keep the pressure above the cut-in pressure. I need to do more research after the snow melts!
  9. #29
    Super Member
    Join Date
    Feb 2006
    Posts
    6,764
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    More info from a pressure gauge.
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, Hesston Haybine, JD Rake
    Bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  10. #30
    Join Date
    Feb 2013
    Posts
    564
    Meridian, OK
    The info that I need is, Pump on pressure, pump off pressure and will it cycle while the hydrant is open, or what the pressure is, as long as the valve is open. I need to know if the running pressure drops below the turn on pressure.
Similar Threads
  1. Replies: 10
    Last Post: 05-19-2008, 07:28 PM
  2. Water pump
    By Gizmo36 in forum Yanmar
    Last Post: 06-04-2007, 10:42 PM
  3. water pump
    By trumang in forum Parts/Repairs
    Last Post: 05-04-2007, 07:00 PM
  4. Electronic Cistern Water Level Monitor
    By hwp in forum Rural Living
    Last Post: 02-07-2007, 06:48 PM
  5. water pump
    By professor in forum Mitsubishi/Satoh
    Last Post: 10-16-2003, 11:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
